Roll bar from ram charger #1466705
07/11/13 11:55 PM
07/11/13 11:55 PM
ND
flicks5 Offline OP
flicks5  Offline OP
ND
I have a 83 ramcharger that has a factory roll bar in it and I want to know if it will fit into a 84 ram shortbox? any and all help much thanks!!!
Re: Roll bar from ram charger [Re: flicks5] #1466706
07/12/13 01:40 AM
07/12/13 01:40 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
It might fit, if it is a bolt-together roll bar and provided the hoop does not interfere with the rear window in the truck cab. I have a Ramcharger and one of the benefits of this body style is that I can open the rear hatch and insert a roll cage (without the rear legs)almost all the way into place. I can't say the same for the truck cab.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Roll bar from ram charger [Re: Polarapete] #1466707
07/12/13 02:49 AM
07/12/13 02:49 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Sure it'll fit but will be about 4-6" from the front of the bed back thus leaving a big gap. Ramchargers are Shorter so the span from fenderwell to where it sits is less than what a tuck calls for
Re: Roll bar from ram charger [Re: 76dodgeboy] #1466708
07/12/13 02:53 AM
07/12/13 02:53 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I dont believe he means Inside the cab. If it is No it won't
