Carter 6903 BB mech. fuel pump problem? #1466627
07/11/13 08:07 PM
07/11/13 08:07 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
Have a 6903 on my 440. Supposed to be rated at 5.5-6.5 psi. I finally got around to mounting a gauge on it after chasing a rich idle condition that I've never been able to cure. Gauge reads 8.5 psi. I'm pretty sure that's to much pressure for my 4150 800cfm Holley. What are my options here? Can I put a regulator on it? Should I just replace it? Thanks
Re: Carter 6903 BB mech. fuel pump problem? [Re: rck850] #1466628
07/11/13 08:26 PM
07/11/13 08:26 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Put on a regulator
Did you confirm the gauge you are using is reading right ?
Re: Carter 6903 BB mech. fuel pump problem? [Re: JohnRR] #1466629
07/11/13 08:29 PM
07/11/13 08:29 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
gauge was on another regulator that was confirmed to be reading right. I should also say this pump has been on this car since 2002. I have had this problem pretty much since day one so whatever is wrong it's been this way for 11 years.
Re: Carter 6903 BB mech. fuel pump problem? [Re: rck850] #1466630
07/12/13 01:24 PM
07/12/13 01:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You're lucky, I had one that put out 11 psi....had to install a regulator.
