Re: 10 sec small block 340's
[Re: Sb Valiant]
#1465714
07/10/13 01:28 AM
07/10/13 01:28 AM
Posts: 456 corpus christi tex
Cheatham
corpus christi tex
back in 90 built a .030 trw domed stock stoke loosely machined crank and bore clearances stock rods machined on tight side for bearing clamping, o-ringed, usead a narrow rear main bearing, tubed block, external oil lines, X heads I ported, roller .275 @ 050 .628 lift, h/s rockers victor intake 2 in headmans on adapter plates, in 2700 72 duster 5.13 ladder bar 8in turbo action manual v/b 727, 31x13x15 slicks on race fuel 830 carb ran 11.30s on 750alky 10.90s, even with a near stock 340 same car ran 12.20s, it was just a good built car.
[Re: Cheatham]
#1465716
07/10/13 01:45 AM
07/10/13 01:45 AM
Posts: 20,762 A collage of whims
topside
A collage of whims
Not all that hard to do, really: back in the mid-70s my Duster (the Ed Hamburger car) was the first SS/IA car in the 10s and had the NHRA record for a while. Mid-late '90s with a 358" 340, iron W2s, Crane flat tappet, basic 904, 5.38 gear & 13x31 tire, modified SS springs, I was running 10.50s in decent air. Now 368" R1 block, Batten W2s, Comp roller, 6000 stall, otherwise pretty much the same, low 10s @ 3500' DA with an 850 Holley and no real tuning, through race bullet mufflers. By today's standards, nothing really trick: Jack Arnew control arms and a couple of old SS tricks is all. Did have to add wheelie bars after a 300' ride on the rear bumper, though.
[Re: Sb Valiant]
#1465718
07/10/13 09:13 AM
07/10/13 09:13 AM
Posts: 458 Michigan
BPE
Vic's S/ST3040 stock stroke 340, 10.28 to 1,factory cast iron heads that he ported on pump gas. This was the first 9 sec. pass he made, eventually I think it went 9.78 in better air. 904 with a 6250 convertor, 557 gear and a 31" tire. http://www.youtube.com/watch?v=XUqBDDtKYkkRod
[Re: BPE]
#1465720
07/10/13 09:46 AM
07/10/13 09:46 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I was running 10.1s with the engine thats going into my Rampage now... was in the race car as my back up engine... its a 10.6:1 with iron W-2s home ported.. .640/.640 roller, home made headers... back then it was a stock stroke with 4.88 gears and 31" tire... now its a 3.79 stroke and runs 9.50s in the same car
[Re: MR_P_BODY]
#1465721
07/10/13 12:28 PM
07/10/13 12:28 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
One of the better running combo's I have seen was a stock stroke 360. 3200 pound 71 cuda, 727 trans, 8 inch convertor, stock eddies, 525/305 comp hydraulic cam, race demon, about 12 to 1 compression with 1 7/8 headers. ran 10.90's at 121/122 or so, thought that was impressive at that weight with unported heads and a hydraulic camshaft.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#1465722
07/10/13 01:01 PM
07/10/13 01:01 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
I have a stock stroke .030 360 in my car, and have gone 10.56. It's nothing special, kb 107s, .525 solid cam, mild ported eddys, m1 intake and 850 alcohol QF carb. It has a 9" J converter, 727 w/transbrake, and 4.30 rear gear with 29" tires.
[Re: moparguy7074]
#1465723
07/10/13 01:12 PM
07/10/13 01:12 PM
Posts: 1,532 off the grid
340B5
off the grid
From what I've learned w/ my 340;
Torque is the name of the game and a stock stroke 340 doesn't make much down low, so you have to spin it, and of course to spin it you need spring pressure and a cam that works in that rpm range( Im gonna say upwards of 8000 rpm)
If I had to use a stock stroke in a 340 to run 10sec., I'd use a solid roller cam, but still consider a solid flat tappet. Cam timing is everything.
Yeah, it's got a smallblock.
[Re: 340B5]
#1465724
07/10/13 01:18 PM
07/10/13 01:18 PM
Triple Threat
Renton Washington
There is a guy at the local track who had one. 10.70 car
Stock stroke 340, 12-13:1 Ported W2's, big solid roller .700+ lift with 1.6's, 727, 5.13 gears and 29.5" tall slick.
He built a 418 short block for it, changed the gear ratio and the car goes 10.teens now.
[Re: Triple Threat]
#1465726
07/10/13 01:31 PM
07/10/13 01:31 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Buddy of mine has a stock stroke 340, pump gas, Eddy Heads, around a .550 hydraulic roller (can't remember exact), 4.88 gear, 31" tire, 4500 stall, and has gone 8.80's. N/A
[Re: TheOtherDodge]
#1465727
07/10/13 02:23 PM
07/10/13 02:23 PM
Posts: 1,745 Maryland
340_Dart
Maryland
Dragster?
[Re: 340_Dart]
#1465728
07/10/13 02:39 PM
07/10/13 02:39 PM
Triple Threat
Renton Washington
Dragster?
Must be, thats about right, for a 500HP combo to trap 150mph @1800 pounds.
[Re: 340_Dart]
#1465729
07/10/13 04:31 PM
07/10/13 04:31 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Dragster?
Soft 1/8th mile ?
[Re: moparguy7074]
#1465730
07/10/13 04:43 PM
07/10/13 04:43 PM
340_Dart
Maryland
[ I have a stock stroke .030 360 in my car, and have gone 10.56. It's nothing special, kb 107s, .525 solid cam, mild ported eddys, m1 intake and 850 alcohol QF carb. It has a 9" J converter, 727 w/transbrake, and 4.30 rear gear with 29" tires.
Sounds like a strong runner. What cam is it? Any head flow specs?
[Re: tubtar]
#1465731
07/10/13 06:09 PM
07/10/13 06:09 PM
MR_P_BODY
Dragster?
Soft 1/8th mile ?
Thats my opinion.. to run 8.80s in the 1/4 with a 4.88 gear its gonna have to turn well above what a hyd roller will go to.... JMO
