Fuel line & filter question. #1465279
07/09/13 11:52 AM
07/09/13 11:52 AM
United States
tee-john Offline OP
tee-john  Offline OP
United States
What is the best material ( rubber, steel, etc. )to use for a fuel line setup from the fuel pump up to the carb rail? Who has a good flow filter?
Re: Fuel line & filter question. [Re: tee-john] #1465280
07/09/13 12:21 PM
07/09/13 12:21 PM
Steel is far more resistant to vibration cracking over time than aluminum is. Russell makes good filters & I have a 3/8" one with a reuseable sintered (sp) porous metal filter inside & the 2 halves unscrew to get at/clean/reuse the element
Re: Fuel line & filter question. [Re: tee-john] #1465281
07/09/13 12:24 PM
07/09/13 12:24 PM
WV
JohnH Offline
JohnH  Offline
WV
Summit has a good selection of steel lines for Mopar. I have rubber line from my pump to the carb right now, but when I finish the car it will be steel.. Rubber can vibrate and rub a hole can cause a fire. What ever you use make sure it is secure and not vibrating against the engine..
