small block tach drive vacuum advance #1464984
07/08/13 08:03 PM
07/08/13 08:03 PM
midwest
afx man Offline OP
afx man  Offline OP
midwest
I was wondering if any company ever made a vacuum advance tach drive distributor for an "la" (318,340,360) motor?
Re: small block tach drive vacuum advance [Re: afx man] #1464985
07/08/13 10:22 PM
07/08/13 10:22 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Nope. Not for small blocks at least.
I have/had a few tach drives (Accel, MP) none of 'em had vacuum. I guess the reasoning is that if you want/need a mechanical distributor advance mechanism, you're probably wanting a very quick advance curve (or locked out timing) and are not terribly interested in whatever economy a vacuum advance would provide. Since race cars spend most of their time in a narrow rpm band (above 3,000 rpm lets say) there's little part throttle operation where vacuum advance would be of any benefit.
Corvettes and I think older T-birds had them so I could see where your idea came from. I've thought about it myself. No such thing as far as I know though.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: small block tach drive vacuum advance [Re: afx man] #1464986
07/09/13 12:56 AM
07/09/13 12:56 AM
You might see if a std vac adv 2 plate setup with the pivot would fit that dist & cut a window for the can. It may or may not be easily doable. Comparing them side by side would answer that Q pretty quick
Re: small block tach drive vacuum advance [Re: RapidRobert] #1464987
07/09/13 08:41 AM
07/09/13 08:41 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I posted something a little while back asking about parts interchange between the regular vacuum advance distributors and the MP tach drive. They're made by different companies. You might be able to swap the entire mechanism over from the vacuum unit but I never tried it.
I've also wondered if a mechanical tach can be converted to electronic. You'd basically keep the tach face, needle and housing and replace the internal components with electronics.
There's a guy on Ebay (gaugeguy maybe?) that takes your older electric tach or gauges and updates them with new circuit boards so you don't need a tach adapter. Maybe he could tackle that job. Just a thought.
Not sure if you want the cable to be visible for the 'look'.
'71 Duster
'72 Challenger
'17 Ram 1500
