dart trans crossmember #1464969
07/08/13 06:57 PM
07/08/13 06:57 PM
Hamilton,Ohio
P
POZEST Offline OP
POZEST  Offline OP
P
Hamilton,Ohio
Is there any difference between a 71 and 74 Dart trans crossmember? Could the mount be different? If so could the mounts be interchanged? Thanks
Re: dart trans crossmember [Re: POZEST] #1464970
07/08/13 07:27 PM
07/08/13 07:27 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The mount is different, but they bolt into the car the same and the holes in the trans are in the same place...but, you need the whole thing (crossmember and the part that bolts to the trans - 74 used the spool mount, same insert as motor mount).
Re: dart trans crossmember [Re: Jim_Lusk] #1464971
07/08/13 07:30 PM
07/08/13 07:30 PM
Hamilton,Ohio
P
POZEST Offline OP
POZEST  Offline OP
P
Hamilton,Ohio
That's what I was wondering. So as long as I have the 71 cross member and 71 mount together, it will work in a74 correct?
Re: dart trans crossmember [Re: POZEST] #1464972
07/08/13 07:33 PM
07/08/13 07:33 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Yes but the spool mount is far superior if you use the poly bushings..
I am truckless..
Re: dart trans crossmember [Re: 340SHORTY] #1464973
07/08/13 09:58 PM
07/08/13 09:58 PM
Hamilton,Ohio
P
POZEST Offline OP
POZEST  Offline OP
P
Hamilton,Ohio
Okay, thank you.
