Does AVS fit on 383 M1 dual plane without adapter? #1463840
07/07/13 07:34 AM
07/07/13 07:34 AM
Khemi, Stygia
Mebsuta Offline OP
Mebsuta  Offline OP
Khemi, Stygia
Do the AVS/Edelbrock 1405 carburetors fit on the M1 dual plane intake without an adapter?
The M1 dual plane that I'm talking is the one that is an aluminum copy of the 70-71 383 intake. I know most people don't like it (who cares), but it's an aluminum version of the Devil Manifold (2951666) , so I've been thinking about it.
Thanks.
Re: Does AVS fit on 383 M1 dual plane without adapter? [Re: Mebsuta] #1463841
07/07/13 10:44 AM
07/07/13 10:44 AM
I'm almost positive it would since both intake/carb are square bore & both have the modern larger bolt pattern as opposed to the early AFB's smaller/more compact bolt pattern which is why you see the 2 sets of holes (8 total) on some aftermarket intake carb flanges
Re: Does AVS fit on 383 M1 dual plane without adapter? [Re: Mebsuta] #1463842
07/08/13 10:38 AM
07/08/13 10:38 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes , no adapter needed.
