Anyone work at an L.A area dodge dealer? #146342
11/06/08 12:28 AM
11/06/08 12:28 AM
Detroit, MI
CokeBottleKid Offline OP
Detroit, MI
Need help diagnosing an ECU/PCM from a 2001 cummins, more details in this thread.
https://board.moparts.org/ubbthreads/show...e=0#Post4474276
Failing that does anyone have a spare I can swap and try out for kicks?
Re: Anyone work at an L.A area dodge dealer? [Re: CokeBottleKid] #146343
11/06/08 12:36 AM
11/06/08 12:36 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
No help here but a suggestion, rather then plug someone elses good PCM into your broken truck which could potentially have a failed part that might damage the PCM why not plug your PCM into a truck that runs? I've never seen a bad PCM damage any sensors or outputs....Also having a known running vehicle and & ohm meter compare reading at the PCM connector between vehicles...
Re: Anyone work at an L.A area dodge dealer? [Re: 1_WILD_RT] #146344
11/06/08 12:43 AM
11/06/08 12:43 AM
Detroit, MI
Detroit, MI
Well there is no truck...
Swapping ECUs might be OK, PCMs would probably not though unless they don't care if their VTSS might get enabled...
Re: Anyone work at an L.A area dodge dealer? [Re: CokeBottleKid] #146345
11/06/08 12:52 AM
11/06/08 12:52 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
VTSS = Dodge speak, I was a Ford tech & they called it VATS, I quit wrenching about the time it was coming online.....As you were.. I truely don't miss wrenching... I just read through your link..Fun project, be more fun if you had access to the right tools, maybe Troy can hook you up...Parts guys usually know who the good techs are...
Re: Anyone work at an L.A area dodge dealer? [Re: 1_WILD_RT] #146346
11/06/08 02:31 AM
11/06/08 02:31 AM
Detroit, MI
Detroit, MI
Hmmm I forgot about Troy.... oh Troooooooyyyy
