97 DAKOTA; HARD STARTING #146301
11/05/08 11:40 PM
11/05/08 11:40 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
97 Dakota, V6, stick. Just purchased this, knew there is/was a hard starting issue when I bought it, truck had sat awhile before I bought it, so I figured that was the contributing factor. Likes to crank, not a horribly long time, but kinda like when your old carb would load up the motor. Always starts though. Starts the same, whether it's overnight or 1 hour later.
Mimics being flooded, but I don't see black smoke when it starts. Doesn't really run rough other than just after it starts. Just threw a code yesterday. It shows "12".
Doesn't seem to be really using more gas than it has since I bought it, checked the mileage when I bought it, it got 24mpg's my first tank. Doesn't misfire at all under load.
O2 sensor? TPS?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 97 DAKOTA; HARD STARTING [Re: Magnumguy] #146302
11/06/08 01:43 AM
11/06/08 01:43 AM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
code 12 just means the circuit works. it could be a weak fuel pump, plugged fuel filter, or a weak pressure regulator. I'm not an A-1 mechanic, but just throwing out some things I've come across.
Re: 97 DAKOTA; HARD STARTING [Re: 1965_PLYMOUTH] #146303
11/06/08 02:31 AM
11/06/08 02:31 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
girlfriends 94 dakota had same problem..
weak fuel pump...
Tony
70 AARCuda Vitamin C
Re: 97 DAKOTA; HARD STARTING [Re: 70AARcuda] #146304
11/06/08 12:05 PM
11/06/08 12:05 PM
S.E.Ohio
S.E.Ohio
It is 12 years old and the original pump.
I'll dig into that soon, but I'll change the filter first.
But, the "check engine" light came on this week. Would either of them make it "code"?
Re: 97 DAKOTA; HARD STARTING [Re: Magnumguy] #146305
11/06/08 12:12 PM
11/06/08 12:12 PM
S.E.Ohio
S.E.Ohio
Also, is the pressure regulator seperate from the pump?
Re: 97 DAKOTA; HARD STARTING [Re: Magnumguy] #146306
11/07/08 01:31 PM
11/07/08 01:31 PM
Bradenton, Fl 34203
Kilroy was here Offline
Bradenton, Fl 34203
Autozone here runs the codes for free.
My 97 said Front OX Sensor. Put a new one on, ran like a champ. Also had the CRANKSHAFT POSITION SENSOR go out twice.
Re: 97 DAKOTA; HARD STARTING [Re: Kilroy was here] #146307
11/10/08 08:39 PM
11/10/08 08:39 PM
S.E.Ohio
S.E.Ohio
Autozone got no codes, and also informed me the 97's had no external fuel filter, is this so?
Re: 97 DAKOTA; HARD STARTING [Re: Magnumguy] #146308
11/10/08 08:44 PM
11/10/08 08:44 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Very common on newer dodge trucks. *(no fuel filt except in tank)
Re: 97 DAKOTA; HARD STARTING [Re: buildanother] #146309
11/10/08 09:22 PM
11/10/08 09:22 PM
S.E.Ohio
S.E.Ohio
Just wondering. Actually, the truck's been starting/running better having been used more.
