2001 Dodge Durango help #1461955
07/02/13 08:32 PM
07/02/13 08:32 PM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
Okay, this Durango has been a pain in my tail since I traded it in and a friend bought it off the lot. So I ask for assistance...
The shifter cable broke on it a little while ago. She didn't have the money to fix it at the time, so it sat. She had it towed to a Firestone and they replaced it. She gets it back and they say it won't move in 2wd(awd). So I go to mess with it a little. It doesn't move in awd. It moves in 4 high. If you shift to 4 lo, it moves. But it is clearly not in 4-lo when the selector says it should be. Is there an adjustment in the switch or on the transfer case? It doesn't have the tried and true lever. Just an electric switch to fail. This truck is one electrical nightmare(I never had an ounce of problems with it) after another. But I'm trying to work my way through its issues.
Any help is appreciated.
Update. I got it to shift into 4-lo. So the only issue is the awd. Maybe an actuator motor? Maybe something gummed up from sitting?
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 2001 Dodge Durango help [Re: OhioMopar] #1461956
07/03/13 12:08 AM
07/03/13 12:08 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Was it towed on a flat bed? ABS light on?
Re: 2001 Dodge Durango help [Re: NITROUSN] #1461957
07/03/13 05:51 AM
07/03/13 05:51 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
It was towed on a flat bed. I asked her how he loaded it and she said he jumped it and found neutral. No abs light.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 2001 Dodge Durango help [Re: OhioMopar] #1461958
07/06/13 12:24 AM
07/06/13 12:24 AM
pennsylvania
poboyengineering Offline
pennsylvania
sounds like the encoder motor...
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
