Exhaust sound revisited - RRRRRRRR
#1461937
07/02/13 07:47 PM
07/02/13 07:47 PM
Posts: 20,831 A collage of whims
topside
A collage of whims
Some may recall my post a while back about the mufflers for my '64 that runs a healthy BB, headers & 3" X-pipe system with turn-downs at the rear axle. Tacked on some Race Bullets, but as crisp and nasty as they sounded (a +), with the rest of the system just tack-welded together (= gaps), it was LOUD. So, based on a 2.5" system in my other car (with tailpipes, = flawed comparison) I had my muffler guy weld on a pair of 3" Dynomax Super Turbos. One flaw in a comparison is that he welded the pipe gaps last. BUT. Now the car has a ridiculous loud drone like a hum at idle - even outside the car - up to about 2500. Horrible: no crispness, only a loud low-frequency "moan". I've had a few cars without tailpipes and never this, but of course I can't recall their mufflers except 2 had glasspacks (1970s) and smaller tubing. So: any suggestions/sound clips for some crisp-sounding mufflers for this thing that will still flow?
Re: Exhaust sound revisited - RRRRRRRR
[Re: topside]
#1461941
07/03/13 02:59 AM
07/03/13 02:59 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Try a pair of Stainless Works Chambered tubes from SummitRacing or Jegs,... straight thru design, with a louvered inner tube, no glass/packings, you want some backpressure, install them in reverse flow, I run them with a H pipe and cast HP manifolds....nice sound/idle no drone, but when you get on it, everyone knows!
FYI they are available in many sizes/length, I'd recommend the longest length that you can squeeze under the car, I run 36"X 2.5" right after the H pipe
[Re: DAYCLONA]
#1461942
07/03/13 08:31 AM
07/03/13 08:31 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
these mufflers are the ONLY muffler I run, but I buy mine from a Moparts Member who makes each one to order right here in the US.
http://www.classicchambered.com/
**Photobucket sucks**
