727 shifting/slipping issue #1461659
07/02/13 10:45 AM
07/02/13 10:45 AM
Alberta, Canada
K
krisiesmopes Offline OP
K
Alberta, Canada
Ok going to check out some simple stuff this week, kickdown linkage, maybe adjust the bands... I changed the filter/gasket last fall, and it was a little low on fluid, but I topped it up and made no difference.
Trans was built by a reputable mopar transmission guy I have known for years, probably around 96. I bought the MP kit, and a 5:1 kd lever.
Problem is this, 1-2 shifts aok, hard like it should be if on the throttle, but 2-3 it will not unless I let off the throttle some, then it is soft. Also when I hit a certain speed (110 on my speedo, but it is wrong...probably 85-90 or so) it slips, like I get nothing.. it does not keep pulling. Never had this before.
74 Roadrunner 400 console shift. Recently had the carb off, this is why I think kickdown adjustment.
Re: 727 shifting/slipping issue [Re: krisiesmopes] #1461660
07/02/13 12:04 PM
07/02/13 12:04 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Sounds internal.....clutch seals. That would explain the problem getting the trans to shift up to 3rd gear.
Re: 727 shifting/slipping issue [Re: superwrench] #1461661
07/02/13 12:17 PM
07/02/13 12:17 PM
Alberta, Canada
K
K
Alberta, Canada
In that, do you see it as imminent failure?
I have tons of cores here, and have always wanted to give building one a go...maybe I should get a kit, re-read the manuals and just step into it... In preparation of it failing... Or just pull this one and replace the seals? Is that viable, or is it a case of, its open, do it all?
Re: 727 shifting/slipping issue [Re: krisiesmopes] #1461662
07/02/13 12:22 PM
07/02/13 12:22 PM
superwrench Offline
superwrench  Offline
If it slips as you say, Take a smell of the fluid...should smell burnt. To loose any "drive" at all, there has to be a set of clutches in there that are toast.
That means a reseal and clutches at the least.
