Re: Thank You Koffels place
[Re: Clanton]
#1459071
06/27/13 06:56 PM
06/27/13 06:56 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
So did you pull the head and take it up there? Also is the epoxy strong enough to seal a pressurized oil passage with the heating and cooling cycles? Glad the source was found
[Re: Clanton]
#1459073
06/27/13 07:12 PM
06/27/13 07:12 PM
Can you give the full details on this.
[Re: Clanton]
#1459074
06/27/13 07:17 PM
06/27/13 07:17 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Just adding a small heads up on Epoxy. It appears they used Splashzone epoxy which is one of the best out there BUT if you clean it thoroughly and put 2 coat of clear lacquer spray paint on the epoxy it holds up to any alcohol that is in any gas that you may use. I keep a can or two handy and spray it into a small container and apply with a brush.
[Re: ]
#1459077
06/27/13 07:46 PM
06/27/13 07:46 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
He used a sunen cylinder head machine to ream the passage to size[1/4"],cut some 1/4" brake line to length and tapped it into the head up to the turn into the rocker shaft perch and then sealed it with epoxy.it is not a DIY task and it took a couple time to perfect.
[Re: Clanton]
#1459079
06/27/13 08:49 PM
06/27/13 08:49 PM
I see, I thought maybe the head got pooched from whom ever did the porting.
[Re: pittsburghracer]
#1459082
06/27/13 09:38 PM
06/27/13 09:38 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
He's from Akron....cut him some slack... and dont worry, the only alcohol he needs to seal up, is if he breaks his favorite beer mug...
RIP Monte Smith
[Re: roadhazard]
#1459083
06/27/13 09:47 PM
06/27/13 09:47 PM
Clanton
northern,Ohio,USA
Mike sounds like Scott and the crew at Koffel's set you up with a nice professional fix
Pittspukeracer , thanks for the tip on the clear over the epoxy
Now get that thing screwed together and go get us a time slip
the car will be ready by the end of next wk so in the next few weeks I should be able to get out.
#1459084
06/27/13 10:44 PM
06/27/13 10:44 PM
roadhazard
Akron, Ohio U.S.A.
Hey you spelled that wrong. Your getting as bad as that Doc flabbyazz.
No, you spelled that wrong....... he's now known as MajorPayne.ita
Your alright and I don't care what Comp Wedge has to say about ya
[Re: CompWedgeEngines]
#1459086
06/27/13 10:54 PM
06/27/13 10:54 PM
roadhazard
Akron, Ohio U.S.A.
Hey we have the Goodyear Test Track
I drink my in the can & save them Melt them down and forge my own rods
[Re: ]
#1459087
06/27/13 11:03 PM
06/27/13 11:03 PM
BradH
I think that's still what happened... and may have a similar situation with my Hughes CNC-ported Victors in the same location of one or more ports.
