Torque box install #145788
11/04/08 11:02 PM
11/04/08 11:02 PM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
Can this be done on the bare shell of the car while on the rotisserie ? Doors could be put on and cross braces welded in, or should I wait till the car is sitting on its wheels, drive train in? It's a 70 B-body.
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Torque box install [Re: busboy] #145789
11/04/08 11:13 PM
11/04/08 11:13 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, no problem
Re: Torque box install [Re: ScottSmith_Harms] #145790
11/04/08 11:20 PM
11/04/08 11:20 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
seems like that would be the ideal time. Avoid overhead welding whenever possible!! That's my creedo
Re: Torque box install [Re: ScottSmith_Harms] #145791
11/04/08 11:20 PM
11/04/08 11:20 PM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
Yes, no problem
Okay, let me ask the question the other way. Can I install torque boxes on my A-body that is completely done and painted without damaging the finish on the rocker panels?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Torque box install [Re: MadMatt] #145792
11/04/08 11:23 PM
11/04/08 11:23 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I don't see any problem with that but you'll probably need to haze some overspray on them (the boxes) when you are done.
Re: Torque box install [Re: ScottSmith_Harms] #145793
11/04/08 11:48 PM
11/04/08 11:48 PM
busboy Offline OP
busboy  Offline OP
Ok, so it's not necessary to have the car on it's wheels at operational weight, for any body flex, before installing them? I just want to avoid any surprises when it comes off the rotisserie.
