06/25/13 12:14 AM
06/25/13 12:14 AM
Shippensburg, PA
GardnersGotCudas Offline OP
Shippensburg, PA
71 340 with 4 speed it vibrates at 3000 rpms does it have the wrong flywheel I know the flywheel has hole drill into thanks
Re: 71 340 [Re: GardnersGotCudas] #1457827
06/25/13 12:23 AM
06/25/13 12:23 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Going to need a little more info than that, but yes if it has a Ford or Chevy or even a wrong mopar flywheel it will vibrate if out of balance.
Re: 71 340 [Re: ademon] #1457828
06/25/13 12:32 AM
06/25/13 12:32 AM
Shippensburg, PA
Shippensburg, PA
it is a mopar flywheel how do u tell how it is balance mine has holes drill in it thanks
Re: 71 340 [Re: GardnersGotCudas] #1457829
06/25/13 12:42 AM
06/25/13 12:42 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
When is it vibrating parked when you rev it up, or in gear driving?
Re: 71 340 [Re: GardnersGotCudas] #1457830
06/25/13 12:45 AM
06/25/13 12:45 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
If you have the flywheel balanced, have the clutch and pressure plate balanced with it/also.
Re: 71 340 [Re: autoxcuda] #1457831
06/25/13 01:18 AM
06/25/13 01:18 AM
Shippensburg, PA
Shippensburg, PA
vibrates in neutral reving at 3000 rpms nothing was balanced
Re: 71 340 [Re: GardnersGotCudas] #1457832
06/25/13 11:02 PM
06/25/13 11:02 PM
Shippensburg, PA
Shippensburg, PA
can anybody help me
Re: 71 340 [Re: GardnersGotCudas] #1457833
06/25/13 11:53 PM
06/25/13 11:53 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
How is it in gear!! You need to add more details!!! like is this a all new engine? Stock bell housing? Why was the flywheel replaced? Etc.etc. don't be afraid to type out a couple paragraphs about your cars history, setup, any past work done to it, if it always had this problem.....
Re: 71 340 [Re: ademon] #1457834
06/26/13 12:48 AM
06/26/13 12:48 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Hmmmmm.......
Re: 71 340 [Re: ScottSmith_Harms] #1457835
06/26/13 01:07 PM
06/26/13 01:07 PM
dogdays Offline
dogdays  Offline
Pictures! We must have pictures!
R.
Re: 71 340 [Re: GardnersGotCudas] #1457836
06/26/13 01:14 PM
06/26/13 01:14 PM
1971 340 where internally balaced form the factory, the 1972 and 73 340 ad all 360 where externally balanced Take the flywheel and clutch pressure plate to a engine machine shop and have them check it for balance If it vibrates in neutral now with that flywheel and pressure plate and it DID NOT VIBRATE before the new parts are your problem, unless it has a tuning issue
