NP445 worth anything? #1457701
06/24/13 09:08 PM
06/24/13 09:08 PM
Terre Haute, Indiana
bgilbert Offline OP
bgilbert  Offline OP
Hey guys I'm parting a 70's model 4x4 Dodge truck and it has the NP445 in it, not the granny low NP435. Is this thing worth anything?
85 D350 crew with 90 Cummins 6BT Getrag 3.07 93 D350 single cab Getrag 3.54 74 W300 360 4 speed 4.88 70 front/rear
Re: NP445 worth anything? [Re: bgilbert] #1457702
06/24/13 09:13 PM
06/24/13 09:13 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
To someone looking for 1 Id say yes. How much its worth is a nother question..
I am truckless..
Re: NP445 worth anything? [Re: bgilbert] #1457703
06/24/13 09:27 PM
06/24/13 09:27 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Worth more than the np435. A lot of guys like the fact its not cranny first. You can probably get $300-500 if not more. Post it on Ramchargercentral.
Re: NP445 worth anything? [Re: 76dodgeboy] #1457704
06/24/13 09:44 PM
06/24/13 09:44 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Is this just another truck style four speed or is a five speed? Just what kind of tranny is it?
Moparlee
Re: NP445 worth anything? [Re: Robbins] #1457705
06/24/13 09:48 PM
06/24/13 09:48 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
It's a heavy truck trans similiar to a 435 however it has a synchro first and close ratios. I like them much more than the 435.
Sheldon
Re: NP445 worth anything? [Re: Robbins] #1457706
06/24/13 09:49 PM
06/24/13 09:49 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
4spd. I believe its same as granny just not a granny first gear.
Besides and manual trans for a truck is always worth something
Re: NP445 worth anything? [Re: bgilbert] #1457707
06/24/13 11:20 PM
06/24/13 11:20 PM
Des Moines, IA
CoreyWilson Offline
CoreyWilson  Offline
Des Moines, IA
Might throw it up on craigslist too, there's a few truck pullers who run the 445. If you were closer I would be interested in it.
Re: NP445 worth anything? [Re: CoreyWilson] #1457708
06/25/13 01:37 PM
06/25/13 01:37 PM
dogdays Offline
dogdays  Offline
Me too!
It is a heck of a lot better for towing and general driving. The gear splits are much better than most of the 435s, it's synchro in all four gears, Not better for rock crawling but for everything else it's a keeper.
R.
Re: NP445 worth anything? [Re: CoreyWilson] #1457709
06/25/13 05:25 PM
06/25/13 05:25 PM
bgilbert Offline OP
bgilbert  Offline OP
Thanks guys, guess I'll hold onto it instead of scrapping it lol. I truck pull myself and running the ratios it has, makes it wayy too fast. 4.56 1st, 2.28 2nd. Even with 5.13's it's still in the 22-1 range. With the 4.10's the truck has it's at 18-1 in low range.
Re: NP445 worth anything? [Re: bgilbert] #1457710
06/25/13 08:05 PM
06/25/13 08:05 PM
dogdays Offline
dogdays  Offline
It's Third gear that really has me excited. Running a 318 over the mountains, I have to really let the truck slow down before putting it into Third, with my 1.7 or so ratio. The 445 has more like a 1.3 Third ratio, which would get my engine back into its max torque range without revving to the moon for miles at a time.
R.
Re: NP445 worth anything? [Re: dogdays] #1457711
06/25/13 08:49 PM
06/25/13 08:49 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
How can you tell them apart as far as the 435 and the 445?
Moparlee
Re: NP445 worth anything? [Re: Robbins] #1457712
06/25/13 09:11 PM
06/25/13 09:11 PM
bgilbert Offline OP
bgilbert  Offline OP
Data tag on the pto cover or in my case, DRIVING it. For me, 1st and reverse are WAY too fast. 4.56 1st, 5.64 reverse compared to 6.68 and 8.26.
Re: NP445 worth anything? [Re: Robbins] #1457713
06/25/13 10:23 PM
06/25/13 10:23 PM
Greensburg, Pa
Mpetros Offline
Mpetros  Offline
Greensburg, Pa
Case is about a 1" longer on the 445 and usually has a straight shifting lever that has no bend in it after the bend coming out of the top
Re: NP445 worth anything? [Re: Mpetros] #1457714
06/26/13 01:56 AM
06/26/13 01:56 AM
Des Moines, IA
CoreyWilson Offline
CoreyWilson  Offline
Des Moines, IA
We were looking at one as a possibility with an axle gear change and stayed with the 435, but there are some guys running them infront of profab t-cases with a huge selection of gears.
Like Mpetros said, the case is longer on the 445, but there is also a close ratio 435 out there. It's kind of rare from what I've heard, but I picked one up a year ago. I believe it's tagged as a 435A and I think it's the same ratio as the 445
Re: NP445 worth anything? [Re: CoreyWilson] #1457715
06/26/13 02:48 AM
06/26/13 02:48 AM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
Just for reference I swapped the MP435 for a NP445 in my 73 W200 last year. I paid $300 for the tranny in very good working condition.
And as said above, the NP445 is a great improvement to driveability to the truck.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: NP445 worth anything? [Re: blown340] #1457716
06/26/13 11:20 AM
06/26/13 11:20 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
You got it cheap. I've seen them listed for $800 before
Re: NP445 worth anything? [Re: 76dodgeboy] #1457717
06/26/13 01:25 PM
06/26/13 01:25 PM
dogdays Offline
dogdays  Offline
There ARE close ratio NP435s, but they are rare.
On to the NP445 or its twin, the NP4530. Nearly every one I've seen for sale is from a 4x4. Does anyone have a clue on tailshafts/housings for 2wd?
Thanks,
R.
Re: NP445 worth anything? [Re: dogdays] #1457718
06/26/13 08:27 PM
06/26/13 08:27 PM
Des Moines, IA
CoreyWilson Offline
CoreyWilson  Offline
Des Moines, IA
Dogdays,
Hate to run the post off topic so feel free to pm me or start a new one, but what are you interested in knowing about the 445 tailshaft? I've got a 85 or so one ton crew cab 2 wheel drive with a 445 in it. The truck is a few hours away but I can crawl under there the next time I'm home. Also have a close ratio 435 that was behind a big block in a mid 70's W200. I think the guy I got it from said the motor wasn't original so who knows about the origins of the tranny.
Re: NP445 worth anything? [Re: CoreyWilson] #1457719
06/27/13 02:42 PM
06/27/13 02:42 PM
dogdays Offline
dogdays  Offline
Man, I'd appreciate pictures of the tailshaft area. I want to know or guess if an NP435 tailshaft housing will work.
R.
Re: NP445 worth anything? [Re: dogdays] #1457720
06/28/13 12:11 AM
06/28/13 12:11 AM
Des Moines, IA
CoreyWilson Offline
CoreyWilson  Offline
Des Moines, IA
Im on vacation this week but I'll get some pics possibly next weekend. I've got the 445 in the truck, close ratio 435 out of the truck, short tailshaft 435s from the hydraulic clutch setups and a standard 435 in a truck
