Sorry for the delay but I have to work sometime
I flowed my pump today, five tests. In all test there was an open ended piece of 8an line 3' long on the fitting and were ran for 1 minute.
#1
At the pump, gas cap off, just a touch over 2 gallons.
#2
At the bulkhead fitting in the fenderwell right before the regulator, gas cap off. Just a touch under 2 gallons.
#3
Through the regulator and empty filter housing, cap off. 7 quarts.
#4
Same as #3 with filter element in, 7 quarts.
#5
Same as #4 with gas cap on, 7 quarts.
What do you guys think? This is a 150gph pump and it's flowing 120gph without any restriction. Is the 8an from the tank to the pump hurting it?
