Re: Power steering pump pulley not lining w crank pullies?
[Re: cudabitten]
#1457239
06/23/13 05:07 PM
06/23/13 05:07 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
You also using the original crank pulley to your system? There are probably dozens of crank, water pump, PS pump, pulley configurations out there, and if you are mix matching pulley's that could be your problem.
RF-4C Phantom 69-370 Zweibrucken, Germany
