Rimblow and Tuff Wheel Thread Size #1455774
06/20/13 05:53 PM
06/20/13 05:53 PM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
I'm trying to locate the conical style nuts that hold on the rim blow and tuff wheels. What size thread are the three bolts that hold attach a rimblow or tuff wheel? The only place I've found online that sells the nuts for this application is Classic Industries and they want $1.99 a nut and they want $7 shipping...
They've got balls asking that price for nuts.
I’m listening.
Re: Rimblow and Tuff Wheel Thread Size [Re: Big Bad Bee] #1455775
06/20/13 06:02 PM
06/20/13 06:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I got some at Ace hardware. They were rounded open top nuts. I them turned upside down and they worked just like the originals. They came with the nylon lock stuff in them so they never loosened up. I just took the collar with me and tested until I found the right size.
Re: Rimblow and Tuff Wheel Thread Size [Re: stumpy] #1455776
06/20/13 08:07 PM
06/20/13 08:07 PM
Spokane Valley, WA
Spokane Valley, WA
hmmmm that's an idea. I don't know if a nylock nut has enough steel thread or is hardened enough to withstand the jolt of a collision. Probably fine. I have seen all-steel locking nuts that have a somewhat conical end. those might work okay.
I’m listening.
Re: Rimblow and Tuff Wheel Thread Size [Re: Big Bad Bee] #1455777
06/20/13 08:13 PM
06/20/13 08:13 PM
fresno ca
mikeysmopars Offline
fresno ca
The threads are 1/4 x 20 you should locate some orianals, They center just like lugnuts
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Rimblow and Tuff Wheel Thread Size [Re: mikeysmopars] #1455778
06/20/13 08:15 PM
06/20/13 08:15 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
i would install the nuts that was designed for it..
Re: Rimblow and Tuff Wheel Thread Size [Re: mikeysmopars] #1455779
06/20/13 08:21 PM
06/20/13 08:21 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Wish I'd known - I would have thrown some in the box with the cap...
Re: Rimblow and Tuff Wheel Thread Size [Re: YYZ] #1455780
06/20/13 08:34 PM
06/20/13 08:34 PM
Spokane Valley, WA
Spokane Valley, WA
Vlad, I didn't even think about those nuts until the other day. You are the parts king. I received the rubber button from Rimblow Restorations. Great looking piece. Also got the little beauty ring from Dales Cuda Shop. Fits perfectly, and looks good once installed. All I need now is the base and the nuts!
I’m listening.
