Re: Carter AVS tuning problem
[Re: MOPAULY]
#1454754
06/18/13 11:08 AM
06/18/13 11:08 AM
RapidRobert
I'd leave the top on as the floats are OK. Wait for someone who knows that system
[Re: MOPAULY]
#1454758
06/18/13 12:12 PM
06/18/13 12:12 PM
RapidRobert
That is surprising that it is way rich at idle since it was an emissions carb. If the main metering is lean you can convert to the Eddy 2 step rods/shorter pri jets. go a couple of tho richer than whats in there now for a start at least on the "cruise" step & fill the domed metering rod caps with JB weld then cover it with scotch tape then turn it over so the JB will settle flat/even on the tape & let it setup like that for several days
[Re: MOPAULY]
#1454759
06/18/13 12:32 PM
06/18/13 12:32 PM
Challenger 1
Cincinnati, Ohio
I did read up on that a bit, I guess part of an emissions control they were trying to do. I wonder if it's worth messing with beyond this point or just replacing it with something newer. I plan to drive the car quite a bit once it's road ready and the rich idle is pretty obnoxious.
This reminds me of a recent tuneup I gave my car. 600 1405 edlebrock carb on a 340 with a 474 cam.
I got the vacuum gauge and timing light out. I didn't change my timing, 24 initial and 35 total plus vacuum advance.
What I did windup doing is open my idle mixture screws a little and that helped my idle. But also what I think it did was got rid of some of the smell from my exhaust. I have always thought rich idle caused the smell, but I'm now thinking it was a too lean of a idle causing some of the smell? At least in my case.
[Re: Challenger 1]
#1454761
06/18/13 12:41 PM
06/18/13 12:41 PM
Posts: 10,203 Someplace you aren't
SomeCarGuy
Can you get the plugs out and tap it for regular AVS mixture screws? I've never had an AVS with the plugs. Mine always had screws and I could get the idle set right where I wanted it. I think the only ones I have had were 69-71 model carbs.
I want my fair share
[Re: Jim_Lusk]
#1454763
06/18/13 03:01 PM
06/18/13 03:01 PM
Posts: 7,843 Spring Mount, PA
MOPAULY
Spring Mount, PA
If you have that screw all the way in (counter clockwise) that is the richest setting. They have left hand threads so that leaner and richer are the same rotation as a fuel screw.
The manual tells me the opposite? fully seated is lean? right now it's fully seated, rpms go up if you turn clockwise and back it out.
[Re: Jim_Lusk]
#1454764
06/18/13 04:04 PM
06/18/13 04:04 PM
MOPAULY
Spring Mount, PA
Wait, are you saying that full in is all fuel and no air? I may be misunderstanding the purpose of this adjustment...if that is the case, this thread answers it and I've been adjusting it backwards: https://board.moparts.org/ubbthreads/showflat.php?Number=7637012&page=0to that point good thing I didn't have the impact on full hammer when I took the driver side wheels off as they are reverse thread, I didn't realize there were still doing that in '68.
[Re: Jim_Lusk]
#1454771
06/18/13 09:17 PM
06/18/13 09:17 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I believe what you are describing is a backfire device, but I could be mistaken...
Actually it is a hot idle compensator and not on a 68 carb,also,to SCG,there are mixture screws behind the plugs.Here is one with the plugs removed and mixture screws installed.
[Re: 62maxwgn]
#1454772
06/19/13 01:19 PM
06/19/13 01:19 PM
MOPAULY
Spring Mount, PA
any real benefit to this? It will eventually get replaced with a holley so I don't know if I'd bother with it. Plus it takes away from the resto factor should I get to that point.
