Re: Spacer material
[Re: 70duster340]
#145375
11/03/08 11:00 PM
11/03/08 11:00 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
should be able to just get some 1/2" black pipe from the hardware store.....
Re: Spacer material
[Re: 70duster340]
#145376
11/03/08 11:01 PM
11/03/08 11:01 PM
Posts: 8,144 Arkansas
340727dart
Arkansas
Lowe's has spacers like that in their hardware section.
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
Re: Spacer material
[Re: Dart 340]
#145379
11/03/08 11:46 PM
11/03/08 11:46 PM
dartman366
Mt. Vernon, Ohio
Std black pipe will be fine as long as you keep the bolt's tight and don't allow them to loosen and rattle around and eat themselves up, Heck Ford used aluminum for their spacer's.
Re: Spacer material
[Re: Dart 340]
#145380
11/04/08 10:10 AM
11/04/08 10:10 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Well, no doubt that will work, but the stock ones from my car are definitely hardened more than what a pipe would be. I do know year one carries the hardened spacer kit with the long bolt FWIW.
I've got a bag full of them if you know the length.
Re: Spacer material
[Re: Dart 340]
#145381
11/04/08 01:24 PM
11/04/08 01:24 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
Any machine shops near you? They might have some heavy wall tubing. 3/8" ID X 5/8" OD would give you a 1/8" wall. Wouldn't need to be tool steel. As mentioned above, as long as it's tight you'll be fine
