Yes the Mopar MML (multi-mileage lubricant) is a very good chassis lube and should work fine for all of those things, it's the only lube I used when I rebuilt my front suspension,no problems at all. Ehrenberg loves the stuff too. You can get it at your local chrysler dealer, although some dealers won't sell just one tube, you have to buy a case. Depends on the dealer though. I got lucky and one of my local dealers sells it by the single tube. If the counter person doesn't know what they are doing it can be confusing for them as there is a couple different ones ( I had to go through it with the 19 yr old girl working the parts counter) bring the part # with you. I believe it is 4897841AA for the 14.5oz tube. Hope this helps you out.
