Page 3 of 3 1 2 3
Re: Fuel flow thru reg? [Re: emarine01] #1453797
06/18/13 09:40 PM
06/18/13 09:40 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
LOL go have some fun now!
Re: Fuel flow thru reg? [Re: emarine01] #1453798
06/19/13 01:56 AM
06/19/13 01:56 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
2 6an lines one off each reg port to each bowl seems to have solved the problem, But she source of the problem was a kinked line @ the 90* bend to the front bowl that was hidden by the SS cover on the fuel line, When I did the flow testing I dropped that line and straightened out the 90 to go in the bucket thus fixing the kink, I found the kink from cutting the line to shorten it This was nothing but a frustrating fire drill where the testing made no sense, Thankx to all for the help.
Been there............can drive you nutser for sure but hey you found it.
Re: Fuel flow thru reg? [Re: Thumperdart] #1453799
06/19/13 11:31 AM
06/19/13 11:31 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
thats the kinda stuff that happens to me.just went thru the same thing with a coil wire.worked great when i grounded it out but put it back no spark.changed coils ,dist,finally figered it out.
Re: Fuel flow thru reg? [Re: emarine01] #1453800
06/19/13 02:35 PM
06/19/13 02:35 PM
Lots of gremlins out there, the simple stuff will kill you trying to find it
Page 3 of 3 1 2 3
