Re: Fuel flow thru reg?
[Re: emarine01]
#1453800
06/19/13 02:35 PM
06/19/13 02:35 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
2 6an lines one off each reg port to each bowl seems to have solved the problem, But she source of the problem was a kinked line @ the 90* bend to the front bowl that was hidden by the SS cover on the fuel line, When I did the flow testing I dropped that line and straightened out the 90 to go in the bucket thus fixing the kink, I found the kink from cutting the line to shorten it This was nothing but a frustrating fire drill where the testing made no sense, Thankx to all for the help.
Lots of gremlins out there, the simple stuff will kill you trying to find it
