Spacer material #145373
11/03/08 10:22 PM
11/03/08 10:22 PM
70duster340 Offline OP
Where can I find the tube type spacer material used for bolting up the alternator, and getting it lined up with the crank pulley? I checked the local Home depot, but came up empty.
Re: Spacer material [Re: 70duster340] #145374
11/03/08 10:55 PM
11/03/08 10:55 PM
Anybody???
Re: Spacer material [Re: 70duster340] #145375
11/03/08 11:00 PM
11/03/08 11:00 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
should be able to just get some 1/2" black pipe from the hardware store.....
2017 Grand Cherokee Overland
Re: Spacer material [Re: 70duster340] #145376
11/03/08 11:01 PM
11/03/08 11:01 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
Lowe's has spacers like that in their hardware section.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: Spacer material [Re: 70duster340] #145377
11/03/08 11:07 PM
11/03/08 11:07 PM
IN
ahy Offline
ahy  Offline
IN
Autozone, Ace Hardware or Mancini. All would be generic "cut to length" 3/8 spacer tubes. Summit also sells spacer washers in various thicknesses (1/8", 1/16"...) for fine tuning.
Re: Spacer material [Re: 70duster340] #145378
11/03/08 11:28 PM
11/03/08 11:28 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Well, no doubt that will work, but the stock ones
from my car are definitely hardened more than what
a pipe would be. I do know year one carries the
hardened spacer kit with the long bolt FWIW.
Re: Spacer material [Re: Dart 340] #145379
11/03/08 11:46 PM
11/03/08 11:46 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Std black pipe will be fine as long as you keep the bolt's tight and don't allow them to loosen and rattle around and eat themselves up, Heck Ford used aluminum for their spacer's.
Re: Spacer material [Re: Dart 340] #145380
11/04/08 10:10 AM
11/04/08 10:10 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I've got a bag full of them if you know the length.
Re: Spacer material [Re: Dart 340] #145381
11/04/08 01:24 PM
11/04/08 01:24 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Any machine shops near you? They might have some heavy wall tubing. 3/8" ID X 5/8" OD would give you a 1/8" wall. Wouldn't need to be tool steel. As mentioned above, as long as it's tight you'll be fine
Re: Spacer material [Re: Dart 340] #145382
11/04/08 01:38 PM
11/04/08 01:38 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Last time I was at the junkyard I grabbed a few spacers off mopars. Shouldn't need any for quite awhile!
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Spacer material [Re: GoodysGotaCuda] #145383
11/04/08 09:35 PM
11/04/08 09:35 PM
Well, mine are old and nasty looking. I thought it would be a good idea to replace them. The one shorter one that fits behind the alternator is just a small piece of pipe. I was hoping to get another spacer and cut it to length to replace that piece, and get a new one for between the alternator "ears". I had no idea it would be so difficult to locate them. Home Depot had really small spacers, like 1/4 inch, but nothing like I was looking for.
I really appreciate all the replies, folks!
Re: Spacer material [Re: 70duster340] #145384
11/05/08 02:00 AM
11/05/08 02:00 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Local ACO, Lowes, etc., usually have a metals section that sometimes has 3/4" aluminum round stock. Drill hole inside and cut to length.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Spacer material [Re: Evil Spirit] #145385
11/05/08 02:47 AM
11/05/08 02:47 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
TSB Page 1
Re: Spacer material [Re: Snoopy] #145386
11/05/08 02:48 AM
11/05/08 02:48 AM
Snoopy Offline
Snoopy  Offline
TSB Page 2
Re: Spacer material [Re: Snoopy] #145387
11/05/08 10:00 AM
11/05/08 10:00 AM
md
mopars4ever Offline
mopars4ever  Offline
md
what size do you need? These are nos.
Re: Spacer material [Re: mopars4ever] #145388
11/05/08 10:32 AM
11/05/08 10:32 AM
Rallyecharger, those look like exactly what I'm looking for. Where did you get those? Are they still available through the dealer?
Re: Spacer material [Re: 70duster340] #145389
11/05/08 11:09 AM
11/05/08 11:09 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
