Re: Sure Am Glad I Pulled The Pan [Re: MR_P_BODY] #1453467
06/21/13 05:49 PM
06/21/13 05:49 PM
ohio
all spooled up Offline
ohio
did you drive it on the highway in od .. do u have a wide band on it
Re: Sure Am Glad I Pulled The Pan [Re: MR_P_BODY] #1453468
06/21/13 07:07 PM
06/21/13 07:07 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Fortunately you have the experience to be able to figure it out. Just think if you were a rookie. It is frustrating when you try to do a nice job and it keeps fighting you. Hang in there, It's going to be awesome.
Doug
Re: Sure Am Glad I Pulled The Pan [Re: MR_P_BODY] #1453469
06/21/13 09:03 PM
06/21/13 09:03 PM
Arizona
Chris'sBarracuda Offline
Arizona
I got the oil leak fixed it looks like... but I still
need to jet this thing down.. still fat and the plugs
are all loaded up with oil... I'm gonna pick up another
set of plugs today and start fresh... it has 7"-8"
of vac at idle in gear so the PV should be close..
sure hope it doesn't have a oil issue.. the pipes are
still coated with oil(inside)... been trying to run
it long enough to burn it out but I need to run it
harder to clean them out... I dont see any oil when
its idling... I tried the OD today for the first time..
I sure like that
Saw the video Mike, and it looks like an oil problem.. Hope not but there is still time to fix if it is..
Chris..
Re: Sure Am Glad I Pulled The Pan [Re: all spooled up] #1453470
06/21/13 09:10 PM
06/21/13 09:10 PM
MR_P_BODY Offline OP
I've only driven it on my street... its a 55mph road
but I've buzzed it up on it... I do have a wide band
but havent installed yet.. had other problems to worry
about but I will be putting it on this week... its
ready to go on but I didnt want to waste the sensor
being the exhaust is oil soaked... I wanted to get
new plugs for it today but the store I deal with
was out... I'll pick up a fresh set tomorrow... also
my elec fan sensor took a dump when the radiator hose
blew off so I'll replace that tomorrow... it just
runs the fan all the time and I cant get the temp
above 130* with it running like that
Re: Sure Am Glad I Pulled The Pan [Re: Chris'sBarracuda] #1453471
06/21/13 09:21 PM
06/21/13 09:21 PM
I sure like that
Chris..
Its getting much better just running it... I still
believe its my exhaust from the first engine.. being
that my muffs are at the back bumper and on a angle
I think there is a load of oil in them... I'm thinking
of pulling them and spraying brake clean in them and
dumping out what I can... with out running it on the
road with some good exhaust flow it isnt getting hot
enough to burn it out... nothing at idle and its
getting better with reving it
Re: Sure Am Glad I Pulled The Pan [Re: MR_P_BODY] #1453472
06/22/13 05:52 PM
06/22/13 05:52 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
And I thought I was the only one a car fought against. Sorry to hear you're having so much trouble with it. You know it'll be worth it when you're done though.
BTW, Happy Birthday.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Sure Am Glad I Pulled The Pan [Re: I_bleed_MOPAR] #1453473
06/22/13 06:11 PM
06/22/13 06:11 PM
Tim
Thanks on the B-day... I went to change the electric
stat for the fan today... I bought one this morning
and its my luck... it was bad out of the box.. they
will have a new one tomorrow....I think I'm gonna
pull the intake tomorrow to check the backs of the
valves to see if they have oil on them
Re: Sure Am Glad I Pulled The Pan [Re: MR_P_BODY] #1453474
06/22/13 06:31 PM
06/22/13 06:31 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Happy Birthday ! Mike
Re: Sure Am Glad I Pulled The Pan [Re: MR_P_BODY] #1453475
06/22/13 07:55 PM
06/22/13 07:55 PM
Arizona
Arizona
Tim
I hope they are dry..
This is the engine with all the problems on the dyno??
I had one that just wouldn't get the rings seated, so I had to tear it down completely and re hone and used a standard tension ring and finally got them to seat.. Only happened to me one time over the years.
Happy Birthday..
Chris..
Re: Sure Am Glad I Pulled The Pan [Re: MR_P_BODY] #1453476
06/22/13 08:05 PM
06/22/13 08:05 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
x 2 .... P-guy ....and is that 1951 or 1851 ??
Re: Sure Am Glad I Pulled The Pan [Re: dOoC] #1453477
06/22/13 08:20 PM
06/22/13 08:20 PM
ohio
ohio
happy birth day mike do u think you will bring it to joshes race at norwalk in sept
Re: Sure Am Glad I Pulled The Pan [Re: Chris'sBarracuda] #1453478
06/22/13 09:31 PM
06/22/13 09:31 PM
Happy Birthday..
Chris..
No this engine was fine on the dyno.. the first
one trashed out..when it was in the car
Re: Sure Am Glad I Pulled The Pan [Re: MR_P_BODY] #1453479
06/22/13 10:29 PM
06/22/13 10:29 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Happy birthday Mike. Sounds like it is coming around. Just need to get it on a road where you can put the hammer down. Jim
Re: Sure Am Glad I Pulled The Pan [Re: rt66jim] #1453480
06/22/13 10:47 PM
06/22/13 10:47 PM
Thanks... I hope to get out tomorrow afternoon and
get a few miles on it
Re: Sure Am Glad I Pulled The Pan [Re: MR_P_BODY] #1453481
06/22/13 10:55 PM
06/22/13 10:55 PM
Re: Sure Am Glad I Pulled The Pan [Re: ] #1453482
06/23/13 05:19 PM
06/23/13 05:19 PM
Thanks.... I got the fan switch on.. thats working fine..
took the car out for about 8-10 mile run to try and
burn out the exhaust... most of the smoke/oil is gone
but it still has a little.. I believe it still some
residual oil in the muffs.... but when it cools down
I'm gonna pull the intake and look at the back side
of the intakes to see if its a valve seal issue...
I'm thinking I might just pull my back up engine out
of the race car and do a freshen up on it and slap
it in for drag week... I need to do a cranking pressure
check to see if I should order up a set of pistons
if its to high of pressure... that engine has been
good all along.. its my 396 W-2 engine... but if I
remember right its only 11.0:1
EDIT
I found my oil consumption issue... it was sucking in
oil at the bottom of the intake and the head ports..
I'll fix that tomorrow after I go apply for SS...
when I checked all four corners it was like .001 out
top to bottom which is no biggie... BUT I think the
ends must have been bowed down a touch... I'll check
it with my straight edge and if needed mill it(more
of a PITA to set it up than milling it)
