Re: 383 Mag windage tray necessary for 4WD truck?
[Re: Triggerfish]
#1453049
06/15/13 02:06 AM
06/15/13 02:06 AM
Posts: 6,167 Maryland
GO_Fish
Maryland
Tray is not needed for low rpm street use. For a truck, you will never see a difference without the tray.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: dOrk !]
#1453052
06/15/13 10:36 AM
06/15/13 10:36 AM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
If MPG is a concern .... I would consider putting one on ... if it is not that much of a PITA. The TRAY does a decent job pulling oil out of the crank swirling around ... but not as good a scraper would.
That's what I was thinking & during a search on this site, I read the MP tray isn't that good unless you drill holes for drain back. I have a 6 qt MP rear sump pan & wonder if the tray is recommended for that application. First time I made a gasket with Permatex & think I got way too much on there, so am pulling it off this morning anyway.
[Re: RapidRobert]
#1453054
06/15/13 12:54 PM
06/15/13 12:54 PM
Triggerfish
Blairsden, CA
I just installed it without the tray.
If your up & running I'd let it go as is & put your energy elsewhere . The MP drainback could be an issue if racing but not significantly in your app. The tray/extra gasket changes pickup clearance so might see what you have just for reference if you do go back in there.
Thanks Robert & I just pulled the pan off. Thought I may have applied way too much gasket maker & sure enough, it would've peeled off into the oil. The gray takes quite a while to harden, so may just use The Right Stuff. Drilled 6 3/8"holes in the windage tray for drain back so may as well install it. I could use the rubber gaskets with sealant or adhesive, but there's some small imperfections & scratches in the pan flange, so think gasket maker is the way to go. Messy, but hope it works.
[Re: Triggerfish]
#1453055
06/15/13 03:43 PM
06/15/13 03:43 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
I put the Mopar truck pan on the Dart (383). Fits great with the Alterktion suspension. I used the MP tray too, put some holes in it and chamfered them a bit.
I typically put a thin coat of gasket maker on the gasket itself. Just enough to help it stay in place and fill any small imperfections but not enough to make a mess.
383, Hemi 4-Speed, AlterKtion, D60
[Re: Triggerfish]
#1453057
06/16/13 09:47 AM
06/16/13 09:47 AM
Crazy68Dart
Canton, Ohio
Typically the "form-a-gasket" from Permatex. There are two grades of the stuff, I need to see which one I use.
Like I said, I use the cork gasket, I just skim it with the form-a-gasket on both sides. It has always worked for me. Lots of guys get away with no gaskets, but I typically use gaskets, just my preference.
BTW, I have truck envy, that is awesome!
[Re: Crazy68Dart]
#1453058
06/16/13 11:47 AM
06/16/13 11:47 AM
Triggerfish
Blairsden, CA
Thanks much & what type of gaskets are you using, rubber, rubber/cork or cork?
[Re: Crazy68Dart]
#1453059
06/16/13 12:10 PM
06/16/13 12:10 PM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
Me too, any more pics?
[Re: vdriver]
#1453060
06/16/13 01:37 PM
06/16/13 01:37 PM
Triggerfish
Blairsden, CA
Thanks & here's one from last yr...
[Re: dOrk !]
#1453065
06/17/13 12:55 AM
06/17/13 12:55 AM
Triggerfish
Blairsden, CA
110$ tray ??...??
Its this nylon tray with integral gaskets on both sides. Pretty trick, but tore it when I had to remove cause of leaking. Probably would've worked just fine, if I the PVC was hooked up right..
[Re: RapidRobert]
#1453067
06/17/13 01:58 PM
06/17/13 01:58 PM
Triggerfish
Blairsden, CA
Sure enough, soon as I switched it to the front AND cleaned all the oil out of the valve cover breather & took it for a ride, NO leaks.
That's good it is solved. Clarify this for me, the PCV hose got moved from what port to what port. I'm not grasping what was changed & how that stopped an oil leak at the pan?
The carbs pulls more vacuum off the front inlet than the back. On their site, they say plug the power brakes in the back port & PVC only on the front. My carb builder also verified that it pulls more vacuum from the front side. Here's the Q&A from their site:
Q: Can I run my PCV line to the rear of the carburetor? A: We do not recommend routing the PCV line to the rear of the carburetor. We recommend that the PCV line go to the front, if you have power brakes, they go to the rear.
