Re: 3.9 Dakota with OBD2 P0320, P0351, P0420, P0545
[Re: dgc333]
#145286
11/04/08 09:31 PM
11/04/08 09:31 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
My gut reaction is the cat is plugged, causing it to stall and then it is flagging the other codes. Hard to tell from this end of the keyboard, I won't throw the mechanic under the bus without knowing how much testing has been done thus far. That code sequence doesn't scream PCM failure, but the P0351 could be a faulty driver in the PCM, even as the result of a coil that is shorting out on the primary circuit. A resulting missfire can plug the cat, even without throwing missfire code(s). The A/C code is not likely to be relevant, but I have seen stranger things. The P0320 is odd, usually there is a cam or crank sensor reference and if that is the case, just replace both of them. They are cheap and the PCM does a lousy job of determing which is at fault, DAMHIK HTH, Steve
[Re: Skeptic]
#145287
11/05/08 10:05 AM
11/05/08 10:05 AM
Posts: 173 Indiana
swepty
Indiana
Usually the p0320 is a crank reference not being seen by the pcm. I would put a new sensor in and a pickup while you're at it. The p0351 is lkely to be a coil issue, hopefully not a pcm. I would hang a crank sensor on it and a pickup. If the cat IS plugged, you can take one of the upstream O2 sensors out, leave plugged in, just take it out of the pipe and tie it up out of the way, and see how she runs. If it doesn't stall then put the sensor back in and drive it again, if it stalls with the O2 in and not with it out, you know you have a blockage in the exhaust, either at the cat or muffler.
1976 CREW CAB 3/4 ton 4x4 Factory plow and ex Airforce Truck
1986 Power Ram 400hp 360 6" lift
1970 Plymouth custom suburban 318 4" drop
1996 Dodge 1500 360 4wd 3" lift
North Central Indiana Mopar Club member
