Page 3 of 3 1 2 3
Re: Airwolf heads [Re: pittsburghracer] #1452333
06/16/13 12:16 AM
06/16/13 12:16 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
The Indybrocks ARE offset. Stock small block rockers DON'T fit them
So one is required to buy some form of BIGBLOCK rocker to fit them because of the 150 offset they have that a stock small block head doesn't have
So if you buy Indybrocks you have to buy something you wouldn't have as a small block guy
And if you are using a performance cam you are going to end up with big block Harland Sharps or some other rocker, just like you would use on any quality build
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Airwolf heads [Re: B3422W5] #1452334
06/16/13 06:37 PM
06/16/13 06:37 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Not trying to go off-topic here, but did somebody say the rumored Edelbrock Victors have been back-burnered indefinately?
Why can't somebody just re-make (or reverse engineer) a good quality last production run (the good one) W5?
The Airwolf my is a great head for what I paid for the set I have, whether my particular combo will tap the full potential of them we'll see (my car is going over to the Daurity shop in a week to try to fit up the 1 7/8" TTI's for a start), but I do think they could be a good candidate to an offset rocker, not to just remove the pinch, but to allow the port to widen way out along the lines of the old pro-stock W2's. Probably could get 325-330 out of them at a still reasonable lift and maybe a proportionally larger valve.
I'd been kinda out of the small block stuff for
20 yrs, got frustrated with all the poor MP quality control for a lot of that time. But I'm back into them now and it seems there's a lot of potential for the right casting to come along that allows for a true "mild to wild" built...I suppose something similar to how Indy approached the EZ/EZ-1.
Also wish we could get dart or someone to cast a big bore 4 bolt 48 degree in the 1500-1700 range like all the Chevy/ford stuff that's out there. I think maybe the LS stuff is so good and so plentiful it's really overshadowing the whole aftermarket now.
WIZE
In Car:
Re: Airwolf heads [Re: Streetwize] #1452335
06/16/13 09:11 PM
06/16/13 09:11 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I know for a fact the victor sb head is not dead. It got derailed for a bit., but it will be made.
"Just a Bracket car dressed up like a streetcar"
Re: Airwolf heads [Re: Just-a-dart] #1452336
04/14/14 02:14 PM
04/14/14 02:14 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Just bumping this post back up. Any new builds or track times from anyone?
Keith
Re: Airwolf heads [Re: Dunnuck Racing] #1452337
04/14/14 02:21 PM
04/14/14 02:21 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Crickets chirping.............
Re: Airwolf heads [Re: justinp61] #1452338
04/14/14 03:02 PM
04/14/14 03:02 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
My rocky's got the Airwolfs but I have a low lift Broomstick cam that doesn't really take advantage of them.
The 414 went a real easy 11.16 @ 119 in my 3000 lb w/d Rocky with a slow-n-easy 1.69 60' time. Same motor/drivetrain would likely go 10.70's at 123+ in my old Duster or Dart at the same weight even with the .585/.570 (gross, maybe .545/.530 net) 1.5 rocker cam. I like them but the Rocky's .65 Drag coefficient is not gonna show you the ET's they're capable of.
I bought them since they were a net $500.00 upgrade from my old SDSS Ported eddies that were just a little too small port wise for the 440" I was planning.
WIZE
In Car:
Re: Airwolf heads [Re: Streetwize] #1452339
04/14/14 05:26 PM
04/14/14 05:26 PM
Northern Indiana
Northern Indiana
Wise,
I had read you other post which is what prompted my bumping this post back up. I was hoping somebody had some independent flow numbers or dyno and/ or track times with a more maximized build.
With all the stroker small blocks running around, a head that has more cross section and flow ability should really help especially if a guy can retain all his stock replacement type valvetrain.
I may just have to port a set of Pro Comps. Although the new New Victor may be a better options once they are actually sorted out, even though changes will be necessary.
Keith
Re: Airwolf heads [Re: Streetwize] #1452340
04/14/14 07:06 PM
04/14/14 07:06 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Not real promising from the look of it( the airwolfs)
As an example I used to have a 3450 pound combo that went 10.74 with mildly ported eddies( peak flow 274@600) and a comp flat tappet that was 598/623 with with 1.6 rockers I used. This with a 727.
So with the airwolfs fully ported and in a 400 pound + lighter car and not running even the above ET, they seem down on power.
The above 10.74 was at about 124 with the small Tti step headers and muffs at 11.5 ish compression fwiw.
1.41 best 60 foot
6.56 at 104.17
Re: Airwolf heads [Re: B3422W5] #1452341
04/14/14 08:10 PM
04/14/14 08:10 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Oh I don't know about that, if I put the bullet .668 lift cam and an 8" vert behind this motor and then put it in my old 69 Dart I think it would be a much more fair combination to compare it to. The Rocky is just a play toy, it's got a 9 1/2" street converter in it and a low lift cam. I didn't intend for the Airwolfs to go on this motor....but I'm sure I'm not the only one on Moparts who'se changed plans before ... good enough for me at this stage of my life is...well....good enough!
The heads will be here if I choose to max them out someday...or not. As the combo sits they're really no better than the SDSS 2's I had on it, maybe not as good. But to me that's still better ( and a lot more fun ) than them sitting collecting dust like millions of dollars worth of race parts are all over the country in countless garages.
I used to go wide-open, volume to 11 all the time. Now I find if I don't push it to the limit, I don't go as fast...but I also don't tear stuff up and I get to go out and have fun with my friends a lot more often. And I like that, a lot
Si don't blame the heads just because I concieously chose not to test them to their limits....it runs so sweet I really don't justify changing the cam for the couple of tenths I'm sure is there. Heck if I want to go faster I can pull the tops and gate off the Rocky, maybe I'm just lazy....or maybe it's quick enough for me right now. the only time I ever opened the hood was to show people what it had....never turned a wrench the whole week-end! And my reputation was made not for always having the quickest car, but it was made for always having the car you didn't want to bet against, cause it was always a lot quicker than it looked
WIZE
In Car:
Re: Airwolf heads [Re: Streetwize] #1452342
04/14/14 08:28 PM
04/14/14 08:28 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
That's kinda why I asked if any were being used on a track tested well sorted out race combo. Anyone could and can say well if I did this or I did that it would do this. Heck my 2850 pound pump gas (93) Duster ran 10.06@130mph last year with a 540 lift solid racer brown cam. I ported my Edelbrock heads in a hurry to get back out after my econo W2 heads cracked so they aren't anything special.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Airwolf heads [Re: pittsburghracer] #1452343
04/14/14 08:43 PM
04/14/14 08:43 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Fair enough, PBR!
Just offering what little I know about them from first-hand experience
WIZE
In Car:
Re: Airwolf heads [Re: Streetwize] #1452344
04/14/14 08:58 PM
04/14/14 08:58 PM
PA.
"Little"John
"Little"John
PA.
Fair enough, PBR!
I almost ordered a set twice but honestly I don't think its worth it. I've already hit 318cfm out of the set of edelbrock heads that I am slowly working on right now. I know to go any further I have to move the pushrod over some. I can get intake rockers (8) for 35 dollars each but really how much more can I expect to get cfm wise for the added expense and work. From 243 cfm stock (2.02 valve) to 318 with a lot of work, testing, and a 2.08 valve. I don't think the set I have on the duster now are even flowing 280-285.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Airwolf heads [Re: Streetwize] #1452345
04/14/14 09:28 PM
04/14/14 09:28 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Again.... That cam I ran wasn't even a roller, just a flat tappet. It was 560/585 lift with 1.5 rockers, although I ran it with 1.6's. That wasn't much lift either, especially allowing for deflection.
Just 119 doesn't seem impressive at only 3000 pounds. Those heads I am sure SHOULD have much better numbers up to .550 that those very mildly massaged eddies I ran had, not to mention the extra 450 pound weight difference.
Not trying to pick on ya at all. Just very underwhelming results. Your convertor shouldn't be having much if any effect on the MPH numbers.
The combo I am refering also made several 75 mile jaunts to US131 drag way to lay down those 10.70's... Heck that was 12 or 13 years ago now... Lol
I actually should have just kept that combo( bench seat, column shift, flat hood) instead of deciding to throw money at it to get in the 9's
1.41 best 60 foot
6.56 at 104.17
Re: Airwolf heads [Re: B3422W5] #1452346
04/14/14 09:33 PM
04/14/14 09:33 PM
Toronto
mshred Offline
mshred  Offline
Toronto
IIRC a racer local to you or a buddy is running these heads, right? What has his experience been like?
Re: Airwolf heads [Re: B3422W5] #1452347
04/14/14 10:52 PM
04/14/14 10:52 PM
Northern Indiana
Northern Indiana
I didn't mean to get Wise in a pissing match, which is why I didnt comment on his other post. I just hoped others had tested them by now as Ive heard rumors.
Keith
Re: Airwolf heads [Re: Dunnuck Racing] #1452348
04/14/14 11:06 PM
04/14/14 11:06 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
The Rocky's lack of aero costs it about 45 hp at the stripe compared to an A body regardless of being the same weight, but I ain't complainin'....just sayin
Put whoevers motor you want in it back to back, the physics will be the same....
Piss away
WIZE
In Car:
Re: Airwolf heads [Re: Dunnuck Racing] #1452349
04/14/14 11:41 PM
04/14/14 11:41 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
I would have to think most people in the market for Edelbrock RPMs or Air Wolfs, aren't considering them for a max effort small block.
I've been a Big block guy for 33 years. I understand all the nuances, pro's and cons, to everything from OOTB Stealths to Eddie RPMs, Stage VIs, SRs,-1s,B-1s etc. But when the ported X heads cracked on my 389 small block, I had no idea which way to go.
I decided on the Airwolfs based on the criteria of re-using my headers, rockers, etc. The advertised numbers looked better than most of the numbers advertised by commercially available Edelbrock Rpms. My 428 dynoed at 615 at 6500 with a 600 lift flat tappet cam, and while it peaked at 542 ft. lbs. at 4900, it was over 500 from 4200-6400. I'm looking forward to putting that fat torque curve to work on the street!
I couldn't believe the amount of small block guys I talked to who had suffered multiple problems with W-5, and Indy castings, but seemed willing to deal with it for the power numbers they were getting. Likewise, I was shocked at the money some guys are willing to spend to run hard with W-8, and W-9 stuff, made me seem pretty spoiled with all my big blocks! I just refuse to give up reliability, so I tend to be conservative, hopefully in the coming months, and at Drag Week 2014, we will find out if I made the right decision.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Airwolf heads [Re: MoparBilly] #1452350
04/15/14 12:53 AM
04/15/14 12:53 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Had the "unavailable" Ebrock Victor in my hands this weekend in Vegas. Thick deck, indicated that they left material in critical areas for port work. Extra row of bolt holes for the R3 crowd. Raised valve cover rail (anyone who's owned a set of W5's will appreciate that). W5 exhaust port flange (maybe I'll do a build someday around the headers hanging on my wall). ""IF"" these heads would have come out in a timely manner it's what I'd be running. We had two 340 blocks, the headers, and could have made spacers to run our intakes. I loved the performance we got from our W5 mill. It would have been nice to have that same deal with a reliable head of quality casting.
Page 3 of 3 1 2 3
