Re: Airwolf heads
[Re: viperblue72]
#1452301
06/14/13 12:21 AM
06/14/13 12:21 AM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
You would think they should be 2 tenths or maybe a hair more better than well done eddies are... But until somebody throws a good car and combo under them to prove it, nobody knows.
Re: Airwolf heads
[Re: viperblue72]
#1452304
06/14/13 10:43 AM
06/14/13 10:43 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
72 Dodge demon(his screen name) on here posted some times on a different thread. I think a 5.79 from a 6.01 with eddies and different camshaft . Maybe pm him. Also Streetwize is using some and has ran them.
Apples to oranges IMO.
Re: Airwolf heads
[Re: justinp61]
#1452305
06/14/13 11:01 AM
06/14/13 11:01 AM
Posts: 9,888 Weddington, N.C.
Streetwize
Weddington, N.C.
Admittedly my set won't be a good example until I get my combo closer to optimized with a bigger (higher lift) cam and larger tube headers....and that may be a while. Built the Rocky as a play toy snd not as a test bed. Not often I do it but I 'wanted' the Airwolfs to be able to assess them, not that I 'needed' them.
I bought them in anticipation of a larger 440" small block underway, anf they wound up being a couple hundred more out of pocket over the Shady Dell stage 2's I had and sold. I bought Bryce's actual Engine Masters Dyno motor article set.
Re: Airwolf heads
[Re: justinp61]
#1452306
06/14/13 11:36 AM
06/14/13 11:36 AM
Posts: 2,141 junction city oregon
viperblue72
Very true. Will never know what just head swap would do.
Re: Airwolf heads
[Re: 72 Dodge demon]
#1452308
06/14/13 06:33 PM
06/14/13 06:33 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I don't have any apple or oranges but I like the the way the car runs. Haven't had any problems with them and everything bolted up. After the season is over I'll put in my old cam and find out.
Do you mind listing your engine and car details. As accurate as possible. weight, gearing, trans type, headers, conv stall. engine specs. comp, gas, special ring pac, vacuum pump, carbs, intake, fuel octane, ect, ect. THANKS.
Re: Airwolf heads
[Re: domingo]
#1452310
06/14/13 09:48 PM
06/14/13 09:48 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
It's a Pro Comp Electronics Chinese copy of an Edelbrock head... it has powdered metal seats 9not great for life under hard use & big spring pressures) ultra cheap Pro Comp soft bronze guides....
& then They get CNC'd with a very large Edelbrock port program & it magically becomes an "airwolf" head....
Do they make power? I'm sure they do.... so do really big port Edelbrock heads....
Is the castings & parts of a lesser quality? Yep....
FULLY ported W2 is going to make more power than the CNC Airwolf head.....
Have you considered running for office??
Fully ported W2's may make more power... and they weigh more, and they require offset rockers, and they require a new set of headers, and a new intake manifold.
The biggest advantage to edelbrocks over the airwolfs are, you can actually get them! 9 weeks as of now, waiting on a set of airwolfs, so if everyone is in the same boat I am, it's easy to understand why there aren't more on the track yet.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
Re: Airwolf heads
[Re: domingo]
#1452311
06/14/13 09:57 PM
06/14/13 09:57 PM
Posts: 429 Washington
skrews
Washington
According to Dr J's they come with ductile iron seats, and they install their own valve guides.
Re: Airwolf heads
[Re: skrews]
#1452312
06/15/13 04:25 AM
06/15/13 04:25 AM
Streetwize
Weddington, N.C.
My heads have new ductile iron seats and guides that Bryce installed, I have no complaints at all with the quality and materials in my set of Airwolf heads.
