Eddy rpm's on a 413?
#1451951
06/12/13 10:30 PM
06/12/13 10:30 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
with a bore of only 4.1875, will i have issues with eddy rpm's on a 413?
the 2.14 1.81 valves don't leave much room.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Eddy rpm's on a 413?
[Re: Spaceman Spiff]
#1451953
06/13/13 09:47 AM
06/13/13 09:47 AM
The heads on my 413 now are 906's with 2.14/1.81 valves and they fit fine. (I have a pair of Eddy RPM's for it, just haven't put them on yet.)
#1451954
06/13/13 10:17 AM
06/13/13 10:17 AM
Posts: 1,106 Northeast
VincentVega
Northeast
Wouldn't bore notching be a plus in that case?
I bet those heads would roar on a 413, right out of the box. good cfm for a mill that size
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
[Re: dogdays]
#1451956
06/20/13 09:52 PM
06/20/13 09:52 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Do these come with head bolts? looking at summit's website, it makes no mention of them. If not, whats a good set to use? Thanks.
#1451957
06/20/13 10:08 PM
06/20/13 10:08 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
Might work. Valve shrouding problem and bore notch. Other than those issues, should make decent power in stock form, a lot more modified IMO.
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
