How difficult to change upper/lower control arm bushing #1451924
06/12/13 09:11 PM
06/12/13 09:11 PM
Penna
70satelliteguy Offline OP
Penna
How big of a job is this? Best place to get the parts? 70 B body
Thanks Mike
Re: How difficult to change upper/lower control arm bushing [Re: 70satelliteguy] #1451925
06/12/13 09:16 PM
06/12/13 09:16 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
http://www.forabodiesonly.com/mopar/showthread.php?t=180315
Read thru all the postings about your questions in the above link, over at forabodiesonly.com
Should help you out.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: How difficult to change upper/lower control arm bushing [Re: 70satelliteguy] #1451926
06/12/13 09:16 PM
06/12/13 09:16 PM
tucson az
frank Offline
frank  Offline
tucson az
Not difficult. You need special tools. I bought the tools and broke one(the tool) trying to get one of the bushings out. If I ever need to do again I'll remove the control arms and take them to a machine shop and let them remove/install.
Re: How difficult to change upper/lower control arm bushing [Re: frank] #1451927
06/12/13 11:47 PM
06/12/13 11:47 PM
Central TX
roe Offline
roe  Offline
Central TX
Uppers are easy. I bought the tool, basically a threaded bolt and some washers, etc... It was a synch. R&R both sides in 15 mins. The lowers I sent to the machine shop. Will do the same soon. If I had a cheap press I'd do it all myself. PS, it was my first time doing it.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
