I think youd be further ahead to look for the 302 heads, but if you stick with the 360 heads, youd almost have to mill them down to gain anything. also, with anything more than stock of a cam, id recomend getting a higher stall tc assuming your running an automatic. also stay away from single plane intakes and try to find a good duel plane like the Eddy LD4B. I don't think youd gain very much with the adjustable rockers either, but get the 340 springs at the least. with the right combo, you might be getting around 300-320 horse IMHO.
