Re: Any decent less expensive seat covers than Legendary?
[Re: cudabitten]
#1448730
06/07/13 12:38 PM
06/07/13 12:38 PM
Posts: 2,592 None
71rm23
None
I need a set of front seat covers for my 74 cuda, this is the next most expensive item that I need to purchase for my restore. At over 400 bucks, I was wondering about other seat covers?
For the quality, workmanship, and fit, there is no other, IMOP. In the long run, you'll be happier with Legendary. There are some companies that are vendors for them and offer a discount. Check out Dantes or Classic Industries.
[Re: 71rm23]
#1448740
06/09/13 11:50 AM
06/09/13 11:50 AM
You can try my friend Chris McMahon in NY state as he is a true mopar guy and typically makes covers cheaper than Legendary! http://onlineupholsteryandmore.com/Very nice custom covers and can make very close covers to originals as well. Tell him Brian from NJ referred you and he should take care of you. Been a friend of mine since I got my charger over 13 years ago!
[Re: ]
#1448741
06/09/13 02:18 PM
06/09/13 02:18 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Since the question is, less expensive than Legendary... I used pg classic covers in my challenger. I bought them from a private seller that didn't use them. So I saved another $100. Fit was good, not perfect, but I didn't replace the foam. Legendary are more correct and would probably out last the pg covers, but for the price for my cheap driver, they were just what I wanted. My car is no show car, so correctness wasn't a factor.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1448742
06/09/13 03:55 PM
06/09/13 03:55 PM
Posts: 1,281 WI
wannadrag
WI
Those PG covers are pretty much the same a PUI might even be the same.I've used the PUI on some GM stuff,the vinyl is thin but for the money they aren't horrible.They don't compare to to the quality of Legendary.
