What overdrive ratio? .64 .68 or .82? #144832
11/02/08 04:49 PM
11/02/08 04:49 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Im ordering my TKO Tremec 5 speed transmission from Keisler, and need to pick an OD ratio. Which one do you recommend?
Re: What overdrive ratio? .64 .68 or .82? [Re: AHall] #144833
11/02/08 05:02 PM
11/02/08 05:02 PM
the house on the left.
cogen80 Offline
cogen80  Offline
i think i would go with the most od i could get.
play around with this and see what you like
http://www.bigblockdart.com/techpages/speedtire.shtml
Re: What overdrive ratio? .64 .68 or .82? [Re: AHall] #144834
11/02/08 05:05 PM
11/02/08 05:05 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i prefer .82. the others are too steep (in my opinion) unless your running a 4.10 or something really low.
Re: What overdrive ratio? .64 .68 or .82? [Re: lewtot184] #144835
11/02/08 05:09 PM
11/02/08 05:09 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
Agreed on the gears comment. I have the .64 TKO-600 from Keisler with a 3.23 rear and it is hitting like 72 MPH at 1900 RPM, which is honestly too low.
At Christmas I'll have the 3.73 Dana 60 in there and I think the engine will be much happier a few hundred RPMs higher.
Darren
Re: What overdrive ratio? .64 .68 or .82? [Re: Ludington1] #144836
11/02/08 06:21 PM
11/02/08 06:21 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I like their .64 o/d ratio. Knocks the rpms down real good. Play with this calculator here:
http://vexer.com/68rt/speed.html
Me, I would like all the ratio I could get, but then to take advantage of it, I would also go to 4.10 rear gears.
Re: What overdrive ratio? .64 .68 or .82? [Re: AHall] #144837
11/02/08 07:23 PM
11/02/08 07:23 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
depends greatly on what your doing with the car, street, track, solo comp, etc,etc....what axle gear choice will you be using?...tire size?
my Tona' runs a 440/6 w Keislers .64 TKO 600/650, w a dana 60, running 4:10 gears, and a 27 inch tire......hi-way cruising at 70 mph is 2-2200 rpm (max MPG is 22 MPG).....max speed is 140ish MPH at around 5800 RPM......
ask this "guy" he knows!
Re: What overdrive ratio? .64 .68 or .82? [Re: DAYCLONA] #144838
11/02/08 10:17 PM
11/02/08 10:17 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
what are the other gear ratios? would first be deep enough to work with a 3.23 or 2.94? if so, get the .82, otherwise, I'd go with the .68 or .64.
2017 Grand Cherokee Overland
Re: What overdrive ratio? .64 .68 or .82? [Re: DAYCLONA] #144839
11/02/08 11:40 PM
11/02/08 11:40 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Well it's a weekend cruiser that I take to the track once a month- goal is mid to low 12's with the car. (Car weighs 3900 lbs)
currently have a Dana 60 with 3.55's in it.
at 75 mph im currently taching 4500 rpm which isnt good long term on a 440 big block.
Re: What overdrive ratio? .64 .68 or .82? [Re: AHall] #144840
11/03/08 02:58 AM
11/03/08 02:58 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Are you sure you have 3.55's? That MPH/RPM calcs out depending on tire size to 4.10's with a 23" tire to 4.88's with a 27" tire. 3.55's even with a short 23" tire is still running 86.77 mph at 4500. As for which OD ratio to chose it depends on more than just axle ratio. The RPM range your particular combo is "happy" at enters into the mix also. Gearing for a cruise rpm of 1800 with an engine that isn't happy 'till 2500 is as bad or worse than buzzing it down the freeway at 4G's from a MPG standpoint.
Kevin
Re: What overdrive ratio? .64 .68 or .82? [Re: Twostick] #144841
11/03/08 04:11 AM
11/03/08 04:11 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
my 383 stroker is really happy from 2200-2800 for steady cruising.
with the TKO .64, 3.21 gears and 28.5" tire, I was doing 75 at like 1800 rpm. in the picture attached, I was just under 70 and rpms were about 1500. way too low!
it would buck and surge at that rpm, so I couldn't use 5th gear until I was going faster than 75. not good in a state where the highest speed limit is 65! ...at least it was happy to do 60 in 4th gear at 2400 rpm.
I swapped in 4.56s which will give me right at 2500 rpm at 75 mph with 28.5" tires.
**Photobucket sucks**
Re: What overdrive ratio? .64 .68 or .82? [Re: 70Cuda383] #144842
11/03/08 04:12 AM
11/03/08 04:12 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
forgot to attach the pic! (looks like it's time for gas!)
Re: What overdrive ratio? .64 .68 or .82? [Re: AHall] #144843
11/03/08 07:00 AM
11/03/08 07:00 AM
30 miles west of EuroDisney
fbernard Offline
fbernard  Offline
.64 here, car is used for road racing.
As long as you don't need the 5th for racing, .64 is OK (I have a 3.55 rear ratio with 28" tires).
If I was racing really long tracks (or if I had longer gears), I'd have bought the 0.8 ratio. Right now, there's just one track on which I could have used a 5th gear (3/4 mile straight line).
The gear you need depends on whether you want a normal 5 speed or an OD.
Think of the .64 OD as a 6th speed with no 5th. That's exactly how it feels when using it. Skipping one gear. You have to rev higher in 4th before you shift, since there's a big gap between 4th and 5th (twice as much as between the other gears).
Having said that, I can cruise at the posted highway speed limit at 23-2400 RPM, or a bit lower around 2000 RPM.
When I have to drive on 55-limited roads though (90 km/h here), it's really exactly between 4th and 5th, and I have to stay in 4th (or drive slightly above in 5th, 60 is doable, around 1800 RPM).
Re: What overdrive ratio? .64 .68 or .82? [Re: fbernard] #144844
11/03/08 10:54 AM
11/03/08 10:54 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
how big is your cam, etc? with 3.54's I'd look at the .68....
Re: What overdrive ratio? .64 .68 or .82? [Re: AHall] #144845
11/04/08 09:46 AM
11/04/08 09:46 AM
Tennessee
rj8806 Offline
rj8806  Offline
Tennessee
The general rule of thumb when ordering a TKO is what rear gear ratio do you have currently? Typically a rear gear of 3.55 or taller and we would recommend a TKO-500. Gearing of 3.73 or shorter and we say TKO-600. The most important thing to remember is not rear gear ratios but rather when does your motor start to produce torque? If your motor doesn't start building torque until the 2000rpm mark, DON'T pick a tranny that will have you cruising down the highway at 1700rpm's. This will make for a lugging, chugging, bucking ride and you won't be happy.
Personally, I like to have it where I am cruising at about 200-300rpms above where my motor starts to build torque. For instance, my daily driver starts building good torque at 2000rpm's. I picked a rear gear combination and transmission gearing that allows me to cruise at 2250-2300rpm's at 70mph in 5th. This gives me maximum gas mileage and performance at the same time. In fact, my stock gears were 3.27's. I went up to 3.55's just to match the 5th gear ratio in my trans. and I actually increased my gas mileage. This is in a 2000 mustang GT.
Rear gearing is important, the thing to remember when calling for a quote or help is to know when your motor starts to build torque. This will allow you to get a transmission package that you'll be happy with.
Richard
Tech Support
Re: What overdrive ratio? .64 .68 or .82? [Re: patrick] #144846
11/04/08 11:24 AM
11/04/08 11:24 AM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Engle K56.
Re: What overdrive ratio? .64 .68 or .82? [Re: rj8806] #144847
11/04/08 11:28 AM
11/04/08 11:28 AM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Richard
Tech Support
The motor is a built 440ci, stealth aluminum heads, K56 engle cam, headers, 3.55 Dana 60 rear, do I need the TKO 500 or TKO 600?
Re: What overdrive ratio? .64 .68 or .82? [Re: AHall] #144848
11/04/08 11:41 AM
11/04/08 11:41 AM
Tennessee
rj8806 Offline
rj8806  Offline
Tennessee
Richard
Tech Support
As I stated before, with a 3.55 rear gear, we would automatically recommend a TKO-500 based on ratios alone. Before I can give you a good educated answer, I need to know when the motor starts to build torque? 1700rpm? 2000rpm? 2500rpm? etc... This will help us decide which TKO would be better suited for your needs.
Richard
Re: What overdrive ratio? .64 .68 or .82? [Re: rj8806] #144849
11/04/08 11:54 AM
11/04/08 11:54 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
K56 looks to be a 224/224 @.050 cam, and unless they're stock loooow compression pistons, you're probably making decent compression, so I'm guessing you probably have good low RPM manners/torque, and not a lot of "cam surge". how tall are your tires? with your 3.54 ratio, and say, 27-28" tall tires (255-275/6015's) I'd go with a .68 OD. that'll make it very nice on the interstate, cruising in the 2000-2300 RPM range at 70mph, depending on tire size....2nd choice would be the .64, and then I'd maybe look at some slightly shorter tires (say, 26" tall, like a 295/50R15) if you experience any "cam surge" at cruise.
Re: What overdrive ratio? .64 .68 or .82? [Re: rj8806] #144850
11/04/08 12:08 PM
11/04/08 12:08 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Richard
Tech Support
Richard
man I dont know, just bought the car saturday. Would the only way to find that be to get it DYNO'ed?
Re: What overdrive ratio? .64 .68 or .82? [Re: AHall] #144851
11/04/08 01:47 PM
11/04/08 01:47 PM
Tennessee
rj8806 Offline
rj8806  Offline
Tennessee
Yeah, that would be the best way but honestly, if you can't do that, just go drive it and see when to starts to come on strong.
Can't remember if you said it was an auto or 4 speed right now, so just put it in 4th (4 speed) or "D" for auto and cruise down the road and get a feel for when the motor starts to come on strong.
Maybe some of the guru's on here can take your motor specs and cam specs and determine when the cam starts to do it's thing. Most companies that you buy cams from advertise this cam is good for 1700-5600 range or something like that. I personally have no idea about the K56 Engle cam you are using but then again, I don't know too much about Mopars. Sorry, don't hate me but I am a Ford guy thru and thru.
Richard
