Re: truck 5 speeds?
[Re: savoy64]
#1447177
06/19/13 11:05 AM
06/19/13 11:05 AM
Posts: 15,487 Florida
scratchnfotraction
I was reading about the fluid needed but 20$ a quart? 1004 to refill! well gone to far now to skimp on the fluid it needs. from what I can tell this is the early one with the syncronized 1st & revs gears. light duty with a 19 spline input shaft/727 out put shaft/yoke. may have a 1st gear thats not as low as the standerd duty/heavy duty 4500..from what I have read anyways. I suppose I can count the turns of the input to turns of the output to see what the 1st gear ratio is?...correct? wish I knew what gear was behind it for a correct speedo tooth count. it had 37 tooth short pinion/speed sensor housing that i swaped to the 36 tooth gear/727 housing that I would use with 727-3.91-325/50/15 but need to figure in the OD 5 th gear??? anyone do the math??
Re: truck 5 speeds?
[Re: scratchnfotraction]
#1447178
06/19/13 12:26 PM
06/19/13 12:26 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The speedo drive gear on the output shaft is after any OD gearing so the pinion calculations will be the same as a 1-1 top gear trans.
Look in the hole where the adapter fits and mark one drive gear tooth with a grease pencil, then turn the output shaft and count the number of drive gear teeth.
Re: truck 5 speeds?
[Re: savoy64]
#1447182
06/20/13 09:08 AM
06/20/13 09:08 AM
scratchnfotraction
check fifthgearrepair.com for the simplest/cheapest way to fix the fifth gear---it is a simple process that an average mechanic can do in less than one hour---the only failures i have heard about are cummins powered units where the tranny is lugged under load in fifth gear--chev 454 and dodge V10 ones dont have the 5th gear issue so i wouldnt suspect your motor will take it down...bob
I agree, i have read the same thing on the 4500HD lugging/diesel/v-10/4x4 5th gear loss.
I read the 5thgearrepair link and it seems to be for the 4500HD 4x4 10/31 input/output spline only.
I am hoping the 4500LD = light duty with a 19 spline input and a 29 or 30 spline output.(I need to count output,I counted the input )
it decodes to a 3.9/5.2/5.9 gas engine so it may be good to go with no problems, it is low milage under 100,000.
Re: truck 5 speeds?
[Re: savoy64]
#1447184
06/21/13 01:21 AM
06/21/13 01:21 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
My truck has an nv4500, mine shifts very smooth. It's not a short throw like a car, but other than some newer 6 speed trucks I drove... it's the smooth shifting trans I ever shifted.
On the fluid, I'd stick with the factory stuff. Amsoil I believe makes a substitute, but to save 4-5 bucks a quart, think I'd pass. Some places offer the factory style stuff in gallons for much cheaper... but never seem to have any on stock.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: truck 5 speeds?
[Re: Silver70]
#1447185
07/09/13 10:35 PM
07/09/13 10:35 PM
scratchnfotraction
got pics of the shifter end for a a535 trans. whoo hooo! member shortbed88 has a complete D-100 hydro clutch a535 set up, he was nice enuff to pull the shifter and get me pics. this is a gold nugget shifter if anyone finds one. the flats on the side of the ball with no plastic cup sets it apart, it has a thin middle rail 3-4 gear 1-2 ans r-5 gears are the bigger lugs on either side of 3-4 rail. pics are worth a 1000 words when it come to this sort of thing. not many have heard of the a535 much less seen or worked on one.
Re: truck 5 speeds?
[Re: Golden-Arm]
#1447190
07/09/13 11:35 PM
07/09/13 11:35 PM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
I scored a 4500 back as well. Was put behind a V6 in an '88 I had. Are there any other non-hydro bells it will bolt up to? I got the hydro bell and slave set but my '78 Club Shortbox I got back will need the mech. linkage.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
