Re: LET`S TALK AERODYNAMICS....................
[Re: Thumperdart]
#1446806
06/03/13 01:30 PM
06/03/13 01:30 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Looking at your truck the grill block-off makes sense but on a brick of a dart it didn`t help in back to back same day tests........
what if you blocked off the part between the bumper and valance?
[Re: Thumperdart]
#1446808
06/03/13 02:18 PM
06/03/13 02:18 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Maybe this is too fugly for you car but I put 2 small hinges on the lower rad support and some diamond plate and made a air valance but to push air to the radiator. here is a clearer pic of it.
[Re: Thumperdart]
#1446815
06/03/13 09:38 PM
06/03/13 09:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Get the car lower to the ground... cover the whole bottom of the car with thin alum so you dont have drag on all the junk under there... dont let the air get under the car... side mirrors.. gone.... but being your a street car you cant do most of the stuff that will reduce drag... angle of the windshield is too steep..... so basically you cant do much
