Re: Keisler 5spd or Passon 4spd O/D opinions?
[Re: DAYCLONA]
#144704
11/10/08 08:11 PM
11/10/08 08:11 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
But have you ever driven a Pro-shift 833 with a Long V-gate shifter at full throttle??? I have been racing manual transmissions for a while and the #1 complaint of Tremec racers is the shifting effort.Guys with Cobra and Viper transmissions all miss gears because of the internal rail design.Now correct me if I am wrong but aren't these essentially the same basic trans as the Keisler trans??? Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#144705
11/10/08 08:34 PM
11/10/08 08:34 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Gus......everybody wants to be, or thinks they're Ronnie Sox,.......one problem racing the Tremec on the track or street, is losing your concentration, and going back to old school grab and slam shifting, just can't do that with a Tremec,.....3rd gear, if forced, just locks you out,....akin to missing a shift on a 4spd, regardless of the shifter,......comes down to driver skill, and hand dexterity, as well as RPM, traction, etc.......I'm sure ol' Ronnie missed a few too!
[Re: NV69B7RR]
#144708
11/11/08 08:41 AM
11/11/08 08:41 AM
what good is a transmisssion that cant be shifted over 6000rpm???
oh, its good for a show car. thats driven easily.
i want a muscle car that is driven hard. Cant run a 4 sp with steep gears on the street? Why is that?
I run 4.30's in my STREET DRIVEN cuda. 3000 rpm at 55 mph, or 3200 rpms at 60 mph is no big feet for me. thats right where my converter is solid.
if I calculate the cost saving from mileage going from 3200 rpm at 60 mph (9.5 mpg) to 2300 rpm at 70 mph (11.0 mpg if im lucky), I'd need to drive about 150,000 before I make up the cost of a $5000 overdrive system.
[Re: DAYCLONA]
#144709
11/11/08 09:05 AM
11/11/08 09:05 AM
Posts: 227 Tennessee
rj8806
Tennessee
....that sums up the most frequent call I receive. " I can't slam 2nd to 3rd". After I get done explaining to them that the gates are so close together on a TKO that if you go and "hunt" for 3rd, you'll miss it every time. The key to shifting 2nd to 3rd on a TKO, be it a stock in the box, unmodified unit, or a Keisler modified one, is simply pushing the shifter handle straight forward out of 2nd and it will find 3rd all on it's own. I never get a follow up call from people who tried my method and still can't hit 2nd to 3rd.
Let's face it, the gates on an external linkage 4 speed (muncie, A833 or toploader) are further apart and "require" you to go up, over and up again to hit 3rd. Try that method on a TKO and you'll be cussing alot.
Heck, my daily driver mustang (2000 GT) with it's T45, can't shift like the old school 4 speed pattern. I have to shift it the same way a TKO shifts, or I miss 3rd in it as well. Once you get accustomed to shifting it, the TKO is extremely fast and reliable.
Richard Tech Support
#144710
11/11/08 11:06 AM
11/11/08 11:06 AM
Posts: 18,157 Mass
DAYCLONA
Mass
i want a muscle car that is driven hard. Cant run a 4 sp with steep gears on the street? Why is that? I run 4.30's in my STREET DRIVEN cuda. 3000 rpm at 55 mph, or 3200 rpms at 60 mph is no big feet for me. thats right where my converter is solid. if I calculate the cost saving from mileage going from 3200 rpm at 60 mph (9.5 mpg) to 2300 rpm at 70 mph (11.0 mpg if im lucky), I'd need to drive about 150,000 before I make up the cost of a $5000 overdrive system.
I didn't say you couldn't drive a car with steep gears on the street,.....I said your limited to the street!........
How'd you think your 4:30 gear cuda's motor would, if it COULD?, hold together at a 140 MPH!.......I'm running 4:10's in my dana, in my Tona' with a Keisler TKO 600/650, .64 OD.......I can turn 140 MPH with 4:10's.......could you do that?
Gas mileage?.......hows a maximum of 22 MPG with a 450 HP 440/6.....consistently
If you have to "ring" out your car at 6K plus to get it moving .........I think taking advantage of gearing, means less wear and tear on an engine,........And if you think 5th gear is useless on the track.......trust me, I've used it many times
If you enjoy your 4 spd,.....good for you, different strokes for different fokes
[Re: DAYCLONA]
#144711
11/11/08 11:50 AM
11/11/08 11:50 AM
whats your mileage without using the overdrive?
You claim 22mpg??? i find that very hard to believe. not at 70. not at 55mph. maybe at 30 mph. even with your aerodynamic nose.
At .64 od, that 4.10 looks like a 2.62 gear. there was never a 440 6 pack Ive ever seen that got close to that mileage with a 2.76. Maybe 15 mpg at best with a light foot and tiny tiny cam. so you'd have to drive it like a baby even with your mileage master cam
factory cars with 3.23 got 13mpg at best.
Stick some meat under those lobes and your down around 10 mpg.
as for running 140, you run your car on a roundy round track. So besides you, there are probably 3 other guys on here that do that for speed. the rest of them want the overdrive for mileage or for cruising on the freeway.
What I am saying is that the milage difference from turning 3600 rpm to 2300 on the freeway is probably, at the most, 5 mpg. most of these cars get 2500 miles a year MAX due to insurance. and even then, most of that mileage is playing the streets. I wouldnt see any benefit in an od. Im not a power tour guy.
#144712
11/11/08 01:56 PM
11/11/08 01:56 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Dan I have avg 22 MPG recently on a trip from Mass to Georgia (3400 miles roundtrip).....crusing at 70-75 mph,(2000-2200 RPM)....21 hrs straight thru, only stopping for gas, didn't even shut the car off, until I got to my hotel......next day did a few laps around Road Atlanta speedway........total gas cost, round trip was around $450 bucks,.....and gas avg anywhere from $2.50 to $3.50 depending on the state,........I was watching my MPG use, at every fill up, recording my MPG.....22MPG was my avg
If I want to play, I can suck it down to 10 MPG if I have the end carbs open all day!
And as far as your comment that I run "roundy round" tracks, and most guys only want the OD for cruising and highway............I enjoy triple digit speeds on the highway, just as much on a track
for Camming, I run a Crane 470/471 @ 285 duration with anti pump up lifters, and Crane 1.6 rockers....so there's some "beef" there!
Dan,........like I said earlier, if your happy with "old school" thats cool, that's your "bag".....I use to be the same way, I recall when Keisler came out with the Mopar/Tremec swap in the late 90's, and expounded all the virtues of it,....I can recall saying no way I'd do that to any of my cars,........well ... after having done it, A Keisler is now the first thing on the list...I still have my "old school" Challenger T/A 340/6, 4spd 3:91...255/60/15's.......on the street it's a blast to drive, on the highway 60 mph is 3800-4000 RPM!......I hate to take it anywhere because driving long distance just drains you!........A Keisler TKO .64OD is slated for that one when I repaint the car
All I can say is the TKO 5spd lets me enjoy steep gears on the streets, and lets me enjoy knowing I can take the car 1000, 3000 or 4000 miles with out having to change a rear gear set out, or trailering the car......I don't build show poodles or show queens, although I do like my cars to look good!....I build cars to race on the street and track, cruise and enjoy as well......when you have to trailer, or leave a car home because its undrivable,.....thats no fun.........and as far as trying to justify the cost of a Keisler....Why?.....it's just like any other mod,...why put a Hemi in a car, when a /6 gets you from A to B just as well?......You put a Keisler, or anybody elses OD, be it Passon, GV, TKO, etc, etc.......for one thing, a performance aspect, be it the benefits of OD, mileage, reduced wear, or pure driving enjoyment......basically having your cake and eating it too
Another example of the Keisler versitality is several of the G-series (71 wingcars) that I built with the Beinkes (Gary and Pam)......the white 71 Tona' runs a 472 HEMI with one of my custom cast aluminum HEMI sixpack manifolds,....Keisler .64 OD TKO 5spd w/ dana 4:10's.......the car, on it first trip to Carlisle made 18 MPG AVG!(75-80 MPH avg cruising speed))........The orange 71 HEMI Superbird sports one of my HEMI 6 pak inductions as well, runs a .64 Keisler OD,...dana 3:54....dynoed out at 520 HP......avg 16 MPG on the 06 Power Tour( avg cruising speed 90-100 MPH).....and is fully capable of pegging the 150 speedo................Dan I'm not trying to "sell" you on anything here, just expounding the benefits that can be reaped, if you desire?
#144714
11/11/08 03:48 PM
11/11/08 03:48 PM
Posts: 4,912 The Dark Side
Fasbird
The Dark Side
I am running a TKO (Keisler), 440-6(e-brock heads and Huges 535/515 cam), 3.91 cogs, 26" tall rear rubber. I religiously got over 20mpg driving from Chicago to St. Louis to MMW. 24MPG was the high. Made that run three times and was cruising at about 2200rpm at 69-72mph. Just as a reference for the MPG club.
[Re: NV69B7RR]
#144715
11/11/08 05:40 PM
11/11/08 05:40 PM
Posts: 298 Knoxville, TN
KEISLER
super street
super street
Knoxville, TN
I'd really like to thank both Jamie and SHaffi for providing input into this thread. That says a lot about both of them and their products they sell. I really do appreciate hearing their opinions as well. Its nice to know they care about the products they sell. THANK YOU!
Sorry I am late to the game here, and with the exception of Tom Quadrini's sh!tty-as-usual 7 year old comments, I think this is a good discussion.
Only a couple of things to add here:
1. Customer Service - this is our main focus now, and we have VERY FEW complaints. Product is shipped quick now (4-7 days), backorders and other issues very small. We are doing much more volume - including automatics now also.
2. Pricing - a TKO PerfectFit kit runs $3300 (deduct $400 for a standard fit, which will also get the overdrive in the car, but with much more work). The bell modification is No Charge. The sealed release bearing with carrier is $79, clutch disk $69. So the price to do a swap, including brand new high strength computer balanced and painted driveshaft, new crossmember, new speedo cable, new roller pilot bearing, new isolator, new hardware, new pro shifter mechanism, new clutch disk, new releaser bearing is $3448. (And it was $200 less before Tremec's material & energy cost increase October 1.) I don't know how this compares to Passon, because I don't price his stuff, nor expect him to do the same.
So for $3448, there is a lot of value with the Keisler kit. Perhaps lesser value to those that already have a new releaser, new driveshaft, new clutch disk, etc., but still a lot of value.
3. Ratios - the TKO ratios have the smallest step change of the two choices, and this means RPM drop will be the smallest between gear changes.
4. Torque - the TKO 600 is conservatively rated at 600 FT-LB torque. You can easily run 750 FT-LB with no problem whatsoever. During a torque durability test on the dyno at Tremec, the holding fixture broke at 1400 FT-LB, and the transmission had no failure. So how much torque do you need?... John Holmes vs. Dirk Diggler - either way it's overkill.
5. Technology - Keisler kits offer current OEM technology and unparalleled manufacturing capability and metallurgy, along with long-term availability of OE service parts nation-wide. Add to that, perfected accessory products like our bellhousings, hydraulics, dual friction ceramic-metallic/carbon-organic clutch, shifters handles, pedals, and it's an affordable 1-stop shop to make complete swap with unbeatable value. Check out this video interview from SEMA last week here KEISLER at SEMA
We have sold many, many thousands of tranmissions since 2000, and our business remains the #1 Selling Tremec swap kit on the market for good reason. Plus, unlike other johnny-come-lately-wannabe sales guys peddling tremecs, I am a Mopar enthusiast, hands-on restorer and I care about Mopar and many of you know that. I started my business in 1991 restoring dashes for our Mopar muscle cars, then got into manufacturing Chrysler-licensed parts with One More Run, then my own lenses, then into the transmissions. Passon is also a Mopar guy and while we compete, I respect what he does and think he does a good job with the A833.
At the end of the day, it comes down to what fits your budget, your skills, your driving style, etc.
[Re: KEISLER]
#144717
11/11/08 05:57 PM
11/11/08 05:57 PM
Posts: 18,157 Mass
DAYCLONA
Mass
4. Torque - the TKO 600 is conservatively rated at 600 FT-LB torque. You can easily run 750 FT-LB with no problem whatsoever. During a torque durability test on the dyno at Tremec, the holding fixture broke at 1400 FT-LB, and the transmission had no failure. So how much torque do you need?... John Holmes vs. Dirk Diggler - either way it's overkill. Hey Shafi, I know talking to your guys with one of my current "projects"........they were hesitant in using the TKO 5spd 600/650 behind the combo I want to build.......but I kinda made up my mind to test the Keisler TKO 5spd ...behind a 570 CID RB, running an 8-71 1:1 drive F.I.,......looking at 850-900 HP, max 1000 ft lbs......Oh Yeah! .....so how dose that warranty program go again......should I need it
[Re: DAYCLONA]
#144718
11/11/08 06:22 PM
11/11/08 06:22 PM
KEISLER
super street
super street
Knoxville, TN
Hey Mike,
With the new clutch technology we have now, I think you can make it all happen with single disk technology for a totally streetable setup. I did not want to run a twin disk setup due to the inertia of the clutch on the sychros. I didn't want to run a solid hub either. Now we have the solution for that with a ceramic metallic blend that is just fantastic. I am running it in my Dakota R/T with 6-speed.
The other issue is clamp force with the plate, while managing the pedal effort. Again, we are on the cusp of another winner. We are doing the dynamic balance trials tomorrow, then moving forward to vehicle testing. In the meantime, if a heavy pedal is OK, we can use a stage 3+ spec.
The other thing to consider is keeping a spare transmission when racing it with this 1000 FT-LB mega torque. This will improve uptime in case of a breakage on the track. For street, if the tires spin, it is a non-issue - the trans would never see the full torque.
[Re: KEISLER]
#144719
11/11/08 06:41 PM
11/11/08 06:41 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Shafi You know me!...all to well! ........like I told Jeff, I'm looking to build a wheelstander.......so clutch, and the first 2 gears are paramount........going to build a chassis to "hook-it-up" big time.......with gearing in the 4:80-5:30 range........a few "pulls" in the box, then a few passes down the track,......and I want to drive it home!......that's not asking much is it? and yes I was focused on the single disk.....
[Re: VanishPt]
#144721
11/11/08 06:55 PM
11/11/08 06:55 PM
Posts: 18,157 Mass
DAYCLONA
Mass
i have the Spec stage 3 clutch setup. I do not think it is heavy at all.
Well a heavy clutch dosen't bother me Mark,....I had a 3400 lb BorgBeck in my T/A for years!.....are you running a hyd. set up with your Spec clutch?......
[Re: VanishPt]
#144723
11/12/08 01:52 AM
11/12/08 01:52 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Yes I do. I installed my unit in March 06. I think I have the first "Perfect Shift 3" to come off the line. Unit works great > I have about 13k miles on it so far.
The only thing that would make this better is if Chrysler had put that Torsion bar crossmember about an inch higher!
Good to hear Mark!......Thanks,..I'll assume it's in an E body by your "handle"....VanishPt!
