Page 1 of 3 1 2 3
My 1980 D150 Big block swap #1445391
05/31/13 12:08 AM
05/31/13 12:08 AM
Marysville, WA
77ProStreet Offline OP
Marysville, WA
I am posting some pics of my project that I have been working on. Last year I bought back a 440 from a friend that I had built a couple years before. After looking my truck over, I just couldn't bring myself to put a nice clean engine into a greasy, nasty engine compartment. So here is the mess I have gotten myself into....
[image][/image] [image][/image] [image][/image] [image][/image]
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445392
05/31/13 12:23 AM
05/31/13 12:23 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Your not planning to keep that booster with a 440 are you?
Re: My 1980 D150 Big block swap [Re: 76dodgeboy] #1445393
05/31/13 12:25 AM
05/31/13 12:25 AM
wentzville mo
1974PW Offline
1974PW  Offline
wentzville mo
the small break booster didnt fit with my short deck with tall valve covers
Re: My 1980 D150 Big block swap [Re: 76dodgeboy] #1445394
05/31/13 12:26 AM
05/31/13 12:26 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Looks good.. Missed you last Sunday..
I am truckless..
Re: My 1980 D150 Big block swap [Re: 76dodgeboy] #1445395
05/31/13 12:27 AM
05/31/13 12:27 AM
Marysville, WA
Marysville, WA
Nope, Already got the new one on there, just no picture yet.
Re: My 1980 D150 Big block swap [Re: 340SHORTY] #1445396
06/01/13 03:39 AM
06/01/13 03:39 AM
Marysville, WA
Marysville, WA
Sorry Larry, the wife had a few things for me to do. I should be able to come down mid week, my work schedule is light next week. I'll call ya.
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445397
06/01/13 06:20 AM
06/01/13 06:20 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445398
06/01/13 09:15 AM
06/01/13 09:15 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Looks great so far.
Re: My 1980 D150 Big block swap [Re: redraptor] #1445399
06/08/13 02:11 AM
06/08/13 02:11 AM
Marysville, WA
Marysville, WA
Thanks Redraptor!
I finally got some time this week to put the clutch, bell, and 4 speed on the engine. The weekend before I cleaned up the frame and got all that painted. It's not as nice as a lot of your guys trucks, but it's still in the works and I plan on driving it a lot. Here is a pic of some progress. [image][/image] [image][/image]
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445400
06/08/13 02:29 AM
06/08/13 02:29 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
That is very nice. Clean and neatly done. My project may be a little rougher as I am filling in most of the holes in the firewall with sheet steel. My Ramcharger is destined for drag race only. Speaking of the brake booster, I cut the unit in half, reduced the diammeter by 80% and have welded the two halves together to make a mount for the two bolt aluminum master cylinder to the four bolt firewall. Manual brakes for me. I got the M/C from Dr. Diff along with the adjustable pushrod.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: My 1980 D150 Big block swap [Re: Polarapete] #1445401
06/09/13 02:33 AM
06/09/13 02:33 AM
Marysville, WA
Marysville, WA
Thanks PolaraPete, its coming along, I just have to keep going out after work each night and do something. I would like to drive it this summer.
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445402
05/15/14 03:11 AM
05/15/14 03:11 AM
Marysville, WA
Marysville, WA
Update on the truck. I've been working on the bodywork over the winter. Straightened the fenders, put them in epoxy primer and high build primer, block sanded and repeat.... [image][/image]
[image][/image]
[image][/image]
Hood
[image][/image]
tailgate
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445403
05/15/14 03:21 AM
05/15/14 03:21 AM
Marysville, WA
Marysville, WA
I've started on the bed but have decided to weld up the front gas hole. Now I'm taking it over to get the bed and the underside blasted. I am also welding up the seam at the taillight housings. We just got finished with C notching the frame and am waiting for my NEW mustang gas tank to fab up. Will have pics shortly on that.
[image][/image]
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445404
05/15/14 03:26 AM
05/15/14 03:26 AM
Marysville, WA
Marysville, WA
Almost forgot my floorboard repair. Epoxy primer and Fatmat.
[image][/image]
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445405
05/15/14 04:59 AM
05/15/14 04:59 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: My 1980 D150 Big block swap [Re: 340SHORTY] #1445406
05/16/14 01:22 AM
05/16/14 01:22 AM
Marysville, WA
Marysville, WA
Finally took pics of the C notch.
I will be putting the bump stops back on, just haven't done it yet.
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445407
05/16/14 01:30 AM
05/16/14 01:30 AM
Marysville, WA
Marysville, WA
BTW...I see you Larry!
Re: My 1980 D150 Big block swap [Re: 77ProStreet] #1445408
05/16/14 02:15 AM
05/16/14 02:15 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I see you have quality tires on it, not those cheap a$$ BF Good ..
I am truckless..
Re: My 1980 D150 Big block swap [Re: 340SHORTY] #1445409
05/16/14 09:46 PM
05/16/14 09:46 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
looks good.the floor pan gave me a little more confidence about cutting mine out.....dont cut the cab mount....dont cut the cab mount
Re: My 1980 D150 Big block swap [Re: 72d100] #1445410
05/17/14 12:25 AM
05/17/14 12:25 AM
Marysville, WA
Marysville, WA
...don't cut the cab mount....don't cut the cab mount
And don't cut through your gas tank...Ahem...like I did! I wasn't going to use it anyway, but thank GOD it wasn't metal.
Page 1 of 3 1 2 3
