383 Weird Backfire/timing issue
#1444312
05/29/13 04:41 PM
05/29/13 04:41 PM
Posts: 469 Hawaii
Dodgeballs
Hawaii
So I just picked up a 71 Roadrunner 383/auto stock except for MSD Pro Billet (no vacuum advance)/ 6AL/ edelbrock 650/ headers. When I picked it up, it was a dog. Wouldn't even spin the tires. The timing was at 10 deg. I set it to 12 deg with no appreciable difference. Then this morning, I started it up and it was backfiring through the carb. Before checking for vaccum leaks, I turned advanced the timing until I could go WOT without a backfire. The timing is somewhere near 25 or so on the dampener! Well I drove it, the backfire is gone, the car burns out and doesn't ping.
What the heck? Has the dampener slipped? One thing is that the distributor has light green advance springs. I only see silver and blue in the MSD catalog/manuals. The distributor does advance the timing, though i'm not exactly sure how much and at what curve.
Any ideas?
Re: 383 Weird Backfire/timing issue
[Re: Dodgeballs]
#1444313
05/29/13 04:51 PM
05/29/13 04:51 PM
Posts: 5,166 CT
GTX MATT
CT
Well it may have been recurved, but your typical MSD kit only ocmes with bushings to limit dizzy travel to 18 degrees, which would mean you'd want 20 degrees initial at the most. FBO sells bushings for 10 and 14, so if its been played around with it may want 25 degrees, but I doubt that since most people don't know and anyone who would have known how to recurve the distributor properly likely would have had it running strong.
However, that is all in regards to making good power. The engine should still respond okay with less timing, but even 5 to 10 and it shouldn't backfire/ it should rev clean.
It could have very light springs and be advancing at idle, whats the idle speed? Turn it down and see if the timing retards.
Also many timing lights don't like MSD, particularly dial backs. But I'm guessing you're not using a dial back since you don't know the total timing. Slipped balancer is always a possibility too, as you mentioned.
[Re: GTX MATT]
#1444315
05/29/13 05:05 PM
05/29/13 05:05 PM
RapidRobert
It starts good runs good no kickback no ping. All good except for the timing reading on the dampener looks excessive. What Matt said make sure you ain't into the springs at idle which would give you a false initial timing reading (you actually have less than what it's showing). A slipped dampener would sound like a sure fire cause but k.i.s.s. I'd be inclined to think that that's not it. I would make a mark on your dampener 2&1/4" to the right (clockwise) of the TDC slit which is 35.5 degrees & see how close either way you are to that at total advance & post what you get. Holler how it goes. EDIT A mark 1&1/2" to the right (clockwise) of the TDC slit is 24 degrees. does that sound right for what your showing at idle? The rusty reluctor ain't hurting you but yes I'd reset the gap.
[Re: Dodgeballs]
#1444322
05/29/13 08:30 PM
05/29/13 08:30 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Um, I wouldn't start messing with the carb. till you have the timing done. One thing at a time keeps things a little easier.
I have mechanical Aptitude. I can screw up anything.
[Re: Dodgeballs]
#1444324
05/29/13 11:24 PM
05/29/13 11:24 PM
Posts: 5,166 CT
GTX MATT
CT
Arg, I had the wrong info on the reluctor gap and apparently set it too close at .020" and broke the reluctor. I think I might just get a ready to run distributor with vacuum advance instead of messing with this one already. The motor is so close to stock that I would think it would be better to run vacuum advance anyway.
This is what I would do, but it should still work with the MSD.
I don't think they make green springs? The silver ones are the lightest that they offer.
[Re: lokalik]
#1444326
05/30/13 12:39 PM
05/30/13 12:39 PM
dogdays
TDC is when the piston is at the top of its stroke, NOT when the pointer is pointing at the mark. The two may coincide, but sounds to me that's the first thing.
Second, after reading your last post it occurred to me that your distributor may have a problem with the top bearing being loose. My '71 donor pickup 318 had a distributor with so much slop that the points didn;'t open all the time, you could move the cam sideways and open and close the points. Could something like this have happened to your distributor? I mean, how can you have a collision with 0.020" clearance? Stock is, I believe, 0.008".
R.
