Correct leaf spring U-bolt size #144426
11/01/08 07:18 PM
11/01/08 07:18 PM
Space Station #5
471Magnum Offline OP
Space Station #5
Did a search, but couldn't find it.
Is the bolt diameter supposed to be 9/16" or 1/2"?
I know I need 3" diam x 7"-ish long.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Correct leaf spring U-bolt size [Re: 471Magnum] #144427
11/01/08 07:54 PM
11/01/08 07:54 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Go to the Mancini site, they have them listed with photos.
Re: Correct leaf spring U-bolt size [Re: Dart 340] #144428
11/01/08 08:04 PM
11/01/08 08:04 PM
Space Station #5
Space Station #5
Been there, done that. No diameter listed.
-Jim
Re: Correct leaf spring U-bolt size [Re: 471Magnum] #144429
11/01/08 08:08 PM
11/01/08 08:08 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Which rear end you need them for, I'll go measure mine if you would like.
Re: Correct leaf spring U-bolt size [Re: Dart 340] #144430
11/01/08 08:16 PM
11/01/08 08:16 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
They are 1/2" diameter. I still have my old set
I changed out last week.
If you are replacing yours keep this in mind.
I bought a set and they are only bent into a U shape. The original set I took off are also
flattened in the U area and have some Grippers formed in there also. I am afraid I bend or crushed
my axle tube some with the new ones. For what it's worth.
Re: Correct leaf spring U-bolt size [Re: Dart 340] #144431
11/01/08 08:30 PM
11/01/08 08:30 PM
Space Station #5
Space Station #5
It's for an 8.75.
Looks like AutoZone has them. Thanks!
-Jim
