Why does the air pressure in my tires keep increasing? #1443694
05/28/13 03:11 PM
05/28/13 03:11 PM
Des Moines IA
Soopernaut Offline OP
Des Moines IA
The last couple of times I've checked my air pressure in my tires I've had to let some air out. The pressure is higher in some tires than it had been previously. I check roughly the same time of day, the vehicle has been sitting in a garage out of direct sunlight and has not been driven prior to checking. I can't figure out why the pressure in 2 of the tires is going up each time. I think it is the same 2 tires each time also.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Why does the air pressure in my tires keep increasing? [Re: Soopernaut] #1443695
05/28/13 03:57 PM
05/28/13 03:57 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Ghost with a air hose in the middle of the night?
It is the beginning of summer and it typically get's warmer.
Re: Why does the air pressure in my tires keep increasing? [Re: Challenger 1] #1443696
05/28/13 03:59 PM
05/28/13 03:59 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
infalation.dang economy
Re: Why does the air pressure in my tires keep increasing? [Re: bonefish] #1443697
05/28/13 04:10 PM
05/28/13 04:10 PM
Franklin CT
syleng1 Offline
syleng1  Offline
Franklin CT
Who check's their pressure more than once a year? That should be a new pole.
Re: Why does the air pressure in my tires keep increasing? [Re: Challenger 1] #1443698
05/28/13 05:37 PM
05/28/13 05:37 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Somewhere on another forum out there....
Leaking tires ?
I keep putting air in my husband's tires every night, and the next day it seems like they are leaking out some and I have to refill them. It happens to the same two tires each time, but I don't see a leak in them. Any ideas ?
(I have no real idea what could be causing it ? )
Re: Why does the air pressure in my tires keep increasing? [Re: OzHemi] #1443699
05/28/13 06:28 PM
05/28/13 06:28 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Are you still running winter air?
Re: Why does the air pressure in my tires keep increasing? [Re: Soopernaut] #1443700
05/28/13 06:58 PM
05/28/13 06:58 PM
M.A.
Fern Offline
Fern  Offline
M.A.
If the tires your running are rated at a lower load range then approved for your car, that will cause the tire pressure to increase when your driving. Sometimes to an unsafe level.
Re: Why does the air pressure in my tires keep increasing? [Re: GTX MATT] #1443701
05/28/13 07:02 PM
05/28/13 07:02 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
A 50/50 mix with Prestone will solve that.
Re: Why does the air pressure in my tires keep increasing? [Re: Fern] #1443702
05/28/13 07:12 PM
05/28/13 07:12 PM
Cincinnati, Ohio
Cincinnati, Ohio
really? I don't see how but I have a open mind and love to learn new things.
Is this going to be like the airplane on a treadmill thread?
Re: Why does the air pressure in my tires keep increasing? [Re: Challenger 1] #1443703
05/28/13 07:25 PM
05/28/13 07:25 PM
Speedway In.
I
IndyDave Offline
IndyDave  Offline
I
Speedway In.
Are the "same 2 tires" on the same "axle"? Is it both fronts or both rears? If so it may be the brakes dragging.
Dave Dusterberg
1979 Aspen R/T (soon to be #19 CAM/T)
2002 Ram 1500 SLT
2005 Magnum R/T
2005 Mustang GT SCCA CAM/C #19
Re: Why does the air pressure in my tires keep increasing? [Re: IndyDave] #1443704
05/29/13 02:57 PM
05/29/13 02:57 PM
Des Moines IA
Des Moines IA
They are at opposite corners. How would dragging brakes cause the air pressure to rise and stay that way? I get that the brakes would run at a hotter temperature but would it really cause the air pressure to go up several PSI every 2-3 weeks?
I just noticed this in the last month or two. I've had the same tires for years and the same alloy wheels which I've had to get remounted due to leaks around the bead. Come to think of it both of the suspected tires were the ones that were remounted. One of those was remounted a couple years ago and I didn't notice an increase last year. I think the other was remounted last year.
The strange thing is I've had this vehicle since Oct of 2001, have had 2 sets of tires during that time and never encountered this before.
Re: Why does the air pressure in my tires keep increasing? [Re: Soopernaut] #1443705
05/29/13 03:00 PM
05/29/13 03:00 PM
dogdays Offline
dogdays  Offline
There's medicine for that.
R.
Re: Why does the air pressure in my tires keep increasing? [Re: Soopernaut] #1443706
05/29/13 03:03 PM
05/29/13 03:03 PM
Cincinnati, Ohio
Cincinnati, Ohio
I'd guess that your tire gauge is failing you.
Re: Why does the air pressure in my tires keep increasing? [Re: Soopernaut] #1443707
05/29/13 03:13 PM
05/29/13 03:13 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Mystery solved. Air is leaking IN.
Re: Why does the air pressure in my tires keep increasing? [Re: Challenger 1] #1443708
05/29/13 03:28 PM
05/29/13 03:28 PM
cataclysm80 Offline
cataclysm80  Offline
yeah, try using a different tire guage. Maybe your old one is wearing out.
Tav
Re: Why does the air pressure in my tires keep increasing? [Re: GomangoCuda] #1443709
05/29/13 03:31 PM
05/29/13 03:31 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Re: Why does the air pressure in my tires keep increasing? [Re: GTX MATT] #1443710
05/29/13 06:26 PM
05/29/13 06:26 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i,d be eyeballin freinds or family.got to be a prankster amung them.
Re: Why does the air pressure in my tires keep increasing? [Re: bonefish] #1443711
05/29/13 06:27 PM
05/29/13 06:27 PM
Cincinnati, Ohio
Cincinnati, Ohio
I liked the inflation idea, the economy does suck.
Re: Why does the air pressure in my tires keep increasing? [Re: bonefish] #1443712
05/29/13 06:29 PM
05/29/13 06:29 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
if you ever figer it out see if you can get your gas tank to do the same thing.
Re: Why does the air pressure in my tires keep increasing? [Re: bonefish] #1443713
05/29/13 06:43 PM
05/29/13 06:43 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Is you garage a constant 32 degrees or has it been warming up with the warmer weather?
