Re: Solvent in oil???
[Re: Leadfoot]
#144318
11/01/08 08:46 PM
11/01/08 08:46 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
I am going to assume the lifters are goners so I plan to replace them tomorrow.
Three oil changes should have purged every nook and cranny IMO. Something is clogged or as has been suggested perhaps the pickup loose so pressure can't build up properly. I wouldn't think the lifters are goners. If they are full of mineral spirits, take them apart and clean them
[Re: Pacnorthcuda]
#144320
11/01/08 09:15 PM
11/01/08 09:15 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
Well assuming it's some kind of beater,I'd fill the crankcase with 2 quarts cheap 30wt,at least 2 quarts MEK,toluene,mineral spirits mix and let it run at low rpm 45 minutes,then drain,repeat as needed until clean. Thats the easy way to deal with it.
[Re: Leadfoot]
#144322
11/01/08 11:24 PM
11/01/08 11:24 PM
Scott Carl
Omaha, Nebraska
It's a fresh 340 right off the stand. The lifters are rattling to beat the band since they've all filled up with this thinned out oil. The oil in the bottom of the drain pan has the consistency of crisco and I assume there is some of the same stuff in the galleys. I was just looking for a way to clean it out without another teardown.
Maybe not a complete tear down but pull the lifters. I don't see having to buy new lifters if you haven't driven or run it hard. Just take each one apart and clean them out. But why is the oil in the pan so thick on a fresh rebuild? Reaction between solvent and oil additives?
[Re: Scott Carl]
#144324
11/01/08 11:47 PM
11/01/08 11:47 PM
Posts: 7,863 Colorado
Leadfoot
Colorado
It's weird. The oil seems to be getting better but the residue on the bottom of the drain pan is almost like glue and straight mineral spirits won't disolve it. I have another set of lifters and I don't have any problem throwing them in but I don't want them to fill up with any of this stuff. I might go for another oil change or two and see what happens before I put them in.
[Re: Leadfoot]
#144326
11/02/08 02:32 AM
11/02/08 02:32 AM
Posts: 616 Sacramento, CA
Kirk_Ingram
super street
super street
Sacramento, CA
An hour and a half, and the engine is out, another hour to take it down. Wash the block, check your cylinder walls for pattern, re-assemble with new bearings and rings and lifters and oil pump. Break-in again...yada...yada... Call it a $200 mistake And whatever you did don't do it again!
Death or Glory...it's just another story.
[Re: Kirk_Ingram]
#144327
11/02/08 03:11 AM
11/02/08 03:11 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
curious how a fresh off the stand engine could have that much sludge/[Edited by Moparts - Keep it clean] built up in it...
and now
waiting for the rest of the story !!!!
I am truckless..
[Re: goldmember]
#144328
11/02/08 01:15 PM
11/02/08 01:15 PM
I don't think the problem is the mineral spirits,something is way wrong. Sorry,I'd pull the intake and check the cam lobes. Even if you had some trace amounts it wouldn't have any effect after an oil change,5 changes later,you got a problem.
I don't know what you mean by "mineral spirits" but most in that category that I know of mix just fine with oil---which means that after you've changed the oil and filter JUST ONCE the problem should be over.
Either you have something like a leak in the intake side of the oil system (pump gasket, oil pickup, etc) that is causing foaming, or else you have coolant/ water in the oil. Either that, or some awful chemical BESIDES "mineral spirits" has somehow gotten into your engine. If you properly inspected and assembled it, I don't know how that possibly could be the case
[Re: Leadfoot]
#144333
11/02/08 08:47 PM
11/02/08 08:47 PM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
are you running a synthetic oil?? maybe running some ATF will help cut the slime/goo substance...
I am truckless..
[Re: NITROUSN]
#144335
11/02/08 11:21 PM
11/02/08 11:21 PM
Posts: 893 Tustin, CA
pishta
Tustin, CA
Could the thick stuff be moly from the assembly lube. As Mineral spirit is a highly refined product of oil in the first place, I dont think the thick crud is insoluable in oil. If you are concerned about running the motor with the foreign stuff in the pan, why not just run the oil pump? Pull the drive gear and chuck the pump with a hex shaft. The lifters are probably still good, just remove the circlip, disassemble and soak in...mineral spirits !
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
[Re: dulcich]
#144337
11/02/08 11:31 PM
11/02/08 11:31 PM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Mineral spirits wont do what you are describing if that is what you had in the crankcase. It mixes perfectly with oil and just thins it out; does not form a sludge of any kind. Sounds to me like you are getting coolant in the oil. That will make a gooey sludge that sinks to the bottom of your drainpan. -dulcich
Exactly. Thats why I said his posts make zero sense.
