Re: Solvent in oil??? [Re: 340SHORTY] #144334
11/02/08 10:00 PM
11/02/08 10:00 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I have to ask are you on retard pills? Why would you be running mineral spirits in a fresh engine? Your posts and what you are doing make zero sense to me.
Re: Solvent in oil??? [Re: NITROUSN] #144335
11/02/08 11:21 PM
11/02/08 11:21 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Could the thick stuff be moly from the assembly lube. As Mineral spirit is a highly refined product of oil in the first place, I dont think the thick crud is insoluable in oil. If you are concerned about running the motor with the foreign stuff in the pan, why not just run the oil pump? Pull the drive gear and chuck the pump with a hex shaft. The lifters are probably still good, just remove the circlip, disassemble and soak in...mineral spirits !
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: Solvent in oil??? [Re: NITROUSN] #144336
11/02/08 11:26 PM
11/02/08 11:26 PM
dulcich Offline
dulcich  Offline
Mineral spirits wont do what you are describing if that is what you had in the crankcase. It mixes perfectly with oil and just thins it out; does not form a sludge of any kind. Sounds to me like you are getting coolant in the oil. That will make a gooey sludge that sinks to the bottom of your drainpan.
-dulcich
Re: Solvent in oil??? [Re: dulcich] #144337
11/02/08 11:31 PM
11/02/08 11:31 PM
N
NITROUSN Offline
NITROUSN  Offline
N
-dulcich
Exactly. Thats why I said his posts make zero sense.
Re: Solvent in oil??? #144338
11/02/08 11:42 PM
11/02/08 11:42 PM
Upper Midwest
Black_Sheep Offline
Black_Sheep  Offline
Upper Midwest
or else you have coolant/ water in the oil.
Have you checked your coolant level?
'69 Plymouth GTX
See you on the street...
Re: Solvent in oil??? [Re: NITROUSN] #144339
11/03/08 07:54 AM
11/03/08 07:54 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Solvent in oil??? [Re: Leadfoot] #144340
11/03/08 10:41 AM
11/03/08 10:41 AM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
I agree with above you need to be checking for a coolant leak.
