Re: TCI aluminum deep pan leaking - Part 2 [Re: NITROUSN] #1442550
05/28/13 01:30 AM
05/28/13 01:30 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Come on??? Do pan bolts really come loose or does the gasket shrink and the bolts need tightening? I would tighten and paint mark them and drive it. My bets are junk gaskets or a leak from somewhere else.
Thats what I was wondering. As the gasket compresses, then seats, it will cause the bolts to loosen up.
They do the same thing on valve cover gaskets, and hose clamps.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: TCI aluminum deep pan leaking - Part 2 [Re: hp383] #1442551
05/28/13 01:39 AM
05/28/13 01:39 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: TCI aluminum deep pan leaking - Part 2 [Re: hp383] #1442552
05/28/13 01:43 AM
05/28/13 01:43 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
If I knew the answer I'd not ask the question.
I know for a fact that when changing trans fluid using the stock steel pan this doesn't happen. But with this aluminum pan the bolts need re-torquing every time I get home from taking the car out and about.
There's nothing leaking from the transmission, only from the gasket area when the bolts loosen up. I'm not making this stuff up. I'm frustrated and sick of messing with it. I'm about ready to go back to a steel pan.
BTW, it's a Fel-pro gasket.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: TCI aluminum deep pan leaking - Part 2 [Re: Junky] #1442553
05/28/13 08:30 AM
05/28/13 08:30 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Go to a Mopar dealer and get a factory gasket.
Re: TCI aluminum deep pan leaking - Part 2 [Re: Junky] #1442554
05/28/13 10:54 AM
05/28/13 10:54 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Call TCI and tell 'em what you're dealing with and get their recommendation...
It's their design...
Re: TCI aluminum deep pan leaking - Part 2 [Re: NITROUSN] #1442555
05/28/13 11:19 AM
05/28/13 11:19 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Is this factory gasket going to work on a non factory aluminum pan?
Re: TCI aluminum deep pan leaking - Part 2 [Re: Junky] #1442556
05/29/13 03:40 PM
05/29/13 03:40 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
I picked up the Mopar gasket #2464324AC. I'm impressed and in hopes this works. I'll let ya all know in a few days.
BTW, it cost me $26,75, but well worth it if it works!
Re: TCI aluminum deep pan leaking - Part 2 [Re: Junky] #1442557
05/29/13 04:05 PM
05/29/13 04:05 PM
scratchnfotraction Offline
remember....longer bolts and do not over torque them.
that gasket will not compress. just that o-ring bead compresses.
Re: TCI aluminum deep pan leaking - Part 2 [Re: scratchnfotraction] #1442558
05/29/13 04:30 PM
05/29/13 04:30 PM
Easton, Minnesota
gpuller Offline
gpuller  Offline
Easton, Minnesota
That gasket is the cats ass, wont smash from over tightening. Use some new bolts and lock washers.
When I posted that price that was from a few years ago. Figured it had to go up in price some.
Re: TCI aluminum deep pan leaking - Part 2 [Re: scratchnfotraction] #1442559
05/29/13 07:56 PM
05/29/13 07:56 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Thanks, Scratchn.
Re: TCI aluminum deep pan leaking - Part 2 [Re: gpuller] #1442560
05/29/13 07:57 PM
05/29/13 07:57 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
I figured so. I posted it just in case someone wanted to know.
Re: TCI aluminum deep pan leaking - Part 2 [Re: Junky] #1442561
05/29/13 08:12 PM
05/29/13 08:12 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
On my Duster...I have a M.P. STEEL deep pan
with the factory rigid gasket that the dealers sell. No more leaks from the pan... Shift shaft seal, that's next on the to do list!
Plymouth Makes It!
