Re: Baby Hemi
[Re: fstfish66]
#1442044
06/24/13 01:44 AM
06/24/13 01:44 AM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
Running my 241 with 3x2 Offenhauser and A833 4spd/3.55 sure-grip in a '36 Plymouth coupe. Great combination, but a bit tricky at times.
what size are the carbs ?? and lets see some pics sounds kool
Re: Baby Hemi
[Re: Ply36]
#1442046
06/25/13 05:30 AM
06/25/13 05:30 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
i'm trying to size the picture as an attachment. no luck yet, still too big.
i can e mail you a free site that will resize your pics,,its free,, i added it to my tool bar let me know,,
i recieved e mails from your replys,but moparts cant find them when i click on them,,, u said rodchester carbs,do you know the cfm by any chance ?? and what makes them think 300 plus horse power ? its a 241 correct ?? did u have higher compression pistons made ? if so where di u get them ?? factory compression is under 7.5 its more like 7.1 advertised, i wonder what it truely is ??? if TRWATERS is around he my chime in,,,stock horse power on a 241 is either 140 or 180 ide have to look but still moves pretty good for that kind of power in my coupe
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
Re: Baby Hemi
[Re: Ply36]
#1442048
07/07/13 10:37 AM
07/07/13 10:37 AM
Posts: 145 lancaster pa
nitrohemi
lancaster pa
I am going to run a 241 in my 26 chrysler sedan. all stock motor. maybe a 4.10 rear with overdrive tranny. I was going to put on a offy 2x2 but may just run the stock 2 barrell with a holley carb.
31 dodge 3 window coupe
67 hemi gtx
2000 prowler
1949 dodge shop truck
Re: Baby Hemi
[Re: Ply36]
#1442049
07/08/13 01:24 AM
07/08/13 01:24 AM
fstfish66
levittown pa
The pistons are custom forged aluminum from JE Pistons and i'm running 10 to 1 c.r., balanced, bored .030 over, 270 degree cam (don't remember lift), and polished intake on the heads. I looked at the documentation on the Rochesters, but didn't see the CFM.
very kool ,,did u have the pistons made or did u get the motor that way ?? intrested in price of pistons and if available,,,
Re: Baby Hemi
[Re: Ply36]
#1442051
07/12/13 12:22 AM
07/12/13 12:22 AM
fstfish66
levittown pa
The pistons were custom made by JE, job # 298446. This was done back in Jan. '02, and the price on the engine builder's shop order for the 8 pistons was $1,054.00.
wow,,i wonder if they kept the mold,or specs ,,,,
Re: Baby Hemi
[Re: fstfish66]
#1442052
07/12/13 12:43 AM
07/12/13 12:43 AM
Posts: 295 Michigan
Ply36
it's been eleven years, but worth a try The shop that did the engine build had to make a clay mold of the top of the cylinder and send that to JE for them to work off of.
