Re: Very dim dash lights 1985 D-150
[Re: tt76400]
#1442027
05/26/13 01:57 AM
05/26/13 01:57 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
check the grounds.. put brighter bulbs in the cluster. LEDS work great..
I am truckless..
[Re: 340SHORTY]
#1442028
05/26/13 08:24 AM
05/26/13 08:24 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Might be the switch.I had several Rams and they all had decent dash lights.The switch goes bad after a while and Ive had a few that the dash lights would not even light till I replace the switch.Rocky
Chrysler Firepower
[Re: therocks]
#1442029
05/26/13 09:44 AM
05/26/13 09:44 AM
Posts: 15,487 Florida
scratchnfotraction
I run a ground wire from Batt inside to the dash ground juction box(metal box looking thing bolted to back side of dash to the left of the radio,it has the key buzzer/wiper delay mounted to it and a stock ground wire from the harness.)
pull your cluster and check to see if any bulbs are blown. mine were dim till I replaced 4 blown bulbs.
on a side not..if you pull the cluster, un-do the speedo cable from the trans so you can pull the cluster out with the cable hooked up,then unhook it, reverse to install.
I have broke a few cable locks at the cluster because it is very short and hard to reach with big paws.
