URGENT - 68 Roadrunner Column Help Needed #1441318
05/24/13 10:09 AM
05/24/13 10:09 AM
tx
N
nobrakesneeded Offline OP
N
tx
I am looking for an exploded view of a 68 RR 4 spd column. I think I may have misplaced a part or two that keeps the inner shaft in place of the sleeve. Please help so that I can drive this car.
Re: URGENT - 68 Roadrunner Column Help Needed [Re: nobrakesneeded] #1441319
05/24/13 10:30 AM
05/24/13 10:30 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Did you check in your 68 service manual ???
Re: URGENT - 68 Roadrunner Column Help Needed [Re: JohnRR] #1441320
05/24/13 10:56 AM
05/24/13 10:56 AM
tx
N
N
tx
Don't have one yet. Just trying to get this last issue resolved so that I can get some miles logged again.
Re: URGENT - 68 Roadrunner Column Help Needed [Re: nobrakesneeded] #1441321
05/24/13 11:31 AM
05/24/13 11:31 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Maybe this will help...
Re: URGENT - 68 Roadrunner Column Help Needed [Re: mopowers] #1441322
05/24/13 05:41 PM
05/24/13 05:41 PM
tx
N
N
tx
Thanks mopowers, the view helps me.
Re: URGENT - 68 Roadrunner Column Help Needed [Re: nobrakesneeded] #1441323
05/25/13 01:26 AM
05/25/13 01:26 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
If you are talking about how the inner shaft slides into the outer shaft, that was a factory poured plastic method designed to break in an accident to prevent injuries.
I have some photos and information on how I repaired mine, if you need it.
