Re: Semi Truck 1 Coronet 0: Need Body Shop in SoCal [Re: autoxcuda] #144124
11/01/08 10:58 PM
11/01/08 10:58 PM
Kahleefahwniah
69CopperCoronet Offline OP
Kahleefahwniah
Too often I hear of accidents that should have happened with classic cars. Most be THINK there stuff handles and breaks well, but the reality is that most are terrible in a panic manuever. No wonder so many wound up in junkyards...I suggest people find a desolate are to check braking under panic stopping. You'd be surprised what a mess most of these cars really are.
Glad you weren't hurt, and the car is fixable.
True in general.
But it doesn't mean this particular accident could be positively avoided if he was driving a new car. Or even a modern sports car. Just if there was still sufficient room left between the minivan for a better braking and maybe handing car.
The newer modern minivan went into the shoulder to avoid what was in front of him also. The minivan didn't trust, or was also too close, for his modern car brakes.
The Coronet made a manuver to the right open shoulder under braking instead of braking in a straight line. Then the minivan did the same and closed the shoulder. Some or all of Coronet tires on the shoulder contacted slippery dirt and debris on the shoulder pavement. The Coronet made a second manuver to the left out of the shoulder and lost traction/control.
In metro So Cal we follow too close. If we followed the 3 sec rule someone would cut us off in that gap.
69CopperCoronet, it wouldn't be a bad idea to think about some 11.75 front disc, adj rear proportioning valve, little stiffer shocks, maybe an aftermarket swaybar.
ive got the ssbc brake system, biggest torsion bars you can buy, biggest sway bars you can buy, boxed lower cas, tubular uppers, urethane everywhere, kybs, 275s out back, 235s up front.
Re: Semi Truck 1 Coronet 0: Need Body Shop in SoCal [Re: 69CopperCoronet] #144125
11/01/08 11:16 PM
11/01/08 11:16 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Well you thought about it... and did it. Dude, you're there allready
Might not hurt to check out the front/rear brake bias. Wet pavement like we had today and someone to watch would do it.
No reason to assume absolutely a new car would not have ended up in the same result.
