2002 dodge ram 1500 4.7 #1440850
05/23/13 01:29 AM
05/23/13 01:29 AM
nc
E
earthmover Offline OP
E
nc
had problems with the trans for a few yrs now...when in rev. it will pull then stop pulling and go back to pulling, I would change the fluid and the filters and all would go back to working for a while....wee now when I put it in rev. it makes a loud noise like the band or something and will not pull at all...what could this be????is this a hard trans to rebuild????whoi has the best kit if I have to rebuild it????could I just go in and adjust the band????????sorry about all the ????? but I am really sick of this truck only have 170 th miles on it and been dealing with the trans for about 2/3 yrs ..thanks
Re: 2002 dodge ram 1500 4.7 [Re: earthmover] #1440851
05/24/13 01:00 PM
05/24/13 01:00 PM
nc
E
E
nc
nobody
Re: 2002 dodge ram 1500 4.7 [Re: earthmover] #1440852
05/24/13 06:04 PM
05/24/13 06:04 PM
IN
ahy Offline
ahy  Offline
IN
170k... sounds like its time for a reman transmission. Not too bad I would say.
Re: 2002 dodge ram 1500 4.7 [Re: ahy] #1440853
05/24/13 06:29 PM
05/24/13 06:29 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
The 45RFE does not use bands to operate. Its all clutch packs to hold whatever gear its in. I personally have not looked much into them but the RFE (rear wheel drive, full electronic control) is nothing like a 904/727 based transmissions of years past. Lots of special tools called out, basic kits are a couple hundred dollars and up.
You may look into a lower mileage used takeout or there are a few places selling remaned ones on ebay with warrenty support. Mopar remans carry a 3 year/100k warrenty, no idea about cost.
The RFE has been around since the 99 grand cherokee came out w/4.7 and it seems to be a decent unit, not heard of any widespread failures. The input & output speed sensors are on the driver side of the case (both same part also). You could try changing them and see if it helps anything. The transmission is totally dependent on an outside 'brain' to operate, garbage in=garbage out.
Re: 2002 dodge ram 1500 4.7 [Re: 135sohc] #1440854
05/24/13 07:54 PM
05/24/13 07:54 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
yeap whole different ball game than a 904/727,all in all a pretty decant trans the speed sensor will have no effect on rev engaging or not
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 2002 dodge ram 1500 4.7 [Re: dusturbd340W5] #1440855
05/24/13 07:57 PM
05/24/13 07:57 PM
Kissimmee Fl.
Kissimmee Fl.
on they did have problems with the cooler line return filters early on
http://www.xkjeeps.com/tsb/tsb_xk_2101505.pdf
